Article for g_uri,g_request
animesh_deshpan
Mega Contributor
Hi ,
I was unable to find any relevant information for 'g_uri','g_request' objects .
Also I needed some more in depth info for 'Navigation Handler' .
Please let me know if there are existing articles for the same , If somehow I might have overlooked.
Please let me know for additional sources which will help me understand .
Thanks in advance for your help.
Animesh
animesh_deshpan
Mega Contributor
Sorry for the delayed response , I still could not find any more updates and articles on these.
Thanks a lot for your inputs.
If it is not documented on the wiki - which is the case for the objects mentioned - it is not recommended to use them in a customer implementation. You may raise a HI incident ticket for it, but most likely they will tell you that these functions are outside the supported area.
zackzhan
Kilo Explorer
I think that you may find your own answer here. http://wiki.servicenow.com/index.php?title=Scoped_GlideServletRequest_API_Reference#gsc.tab=0
Just remember that a scoped api is quite different from global api.
