Auto Flush Execution
Priyanka Mathur
Hi Team,
I have created a auto flush record, I need to delete bulk records from sys_data_source table using auto flush functionality. Could you please assist me on how I can execute this.
Priyanka
Hi Maik,
I did the same thing mentioned the article but didn't get any info or other details. Attached screenshot for reference.
Hi
did you check first whether the Table Cleaner really was executed before?
Kind regards
Maik
Chris Nack
Hi Priyanka,
I know this is an old thread, but I believe you want your Matchfield to be a Date/Time field. Try using sys_created_on instead of sys_created_by (which is the User Id which created the records).
Hi @Priyanka Mathur
The reference article shared by @Maik Skoddow resolves the question and it helped me to understand the scheduled job.
SN KA:
 https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0694151
Like it's mentioned
1. You can navigate to the table 'sys_trigger.list'
2. search for entry  "Table Cleaner' to validate the details
3. As said, it will execute every hour.
This must be in your case as well.
Thanks!
Abhishek Pandey
