how do we create multiple RITMs for a specific use case using service catalog?
Ravish Shetty
hi all,
we have a service catalog wherein we let users request for database access.
Database Group
DB1 Group 1
DB2 Group 1
DB3 Group 2
DB4 Group 2
for the above example, if the access is requested for DB1, we take approval from group 1.
the ask is that we need to create 2 RITMs from the catalog for the above use case based on the approval group
Database Group RITM
DB1 Group 1 RITM111
DB2 Group 1 RITM111
DB3 Group 2 RITM222
DB4 Group 2 RITM222
what is the best way to meet the use case? i can think of creating a custom interface using a ui page or a service portal widget for the same which would programmatically create multiple RITMs upon submission. is there a better and simpler approach to get the same result?
Ravish
Brad Bowman
Mega Patron
Hi Ravish,
We have done this with a CI list box - one RITM is created under the same REQ for each CI selected.  This could also work if you have checkboxes or whatever.  In the workflow for the catalog item we have this Run Script which 'resets' the current RITM to be for only the first CI selected, then creates an RITM for all of the other CIs, populates the same variables, and kicks off this same workflow.  It seems to work pretty well - one Catalog Item with one workflow, and multiple RITMs under the same REQ.
var cilist=[];
var ritmsysid = '';
//get sysids of variables that will be populated on new RITMs
var v_db_cat = '9f29df1bdbe48f004a29df6b5e9619c3';
var v_integration_status = 'bbfcbc9cdb298b00262950a45e961958';
//get multiple values, split into an array
var items = current.variables.v_db_cat.toString();
items = items.split(',');
//if only one item was selected, set the values per usual
if(items.length == 1){
	current.u_on_behalf_of = current.variables.v_requested_for;
	current.cmdb_ci = items[0];
//or else set the values on the initial, existing RITM, and change the selected item to the first one
else{
	current.variables.v_db_cat = items[0];
	//create a new RITM under the same REQ for all of the other selected values
	for (var i = 1; i < items.length; i++) {
		var ritm = new GlideRecord('sc_req_item');
		ritm.initialize();
		ritm.request = current.request;
		ritm.cat_item = current.cat_item;
		ritm.opened_by = current.opened_by;
		ritm.u_on_behalf_of = current.variables.v_requested_for;
		var sysID = ritm.insert();
		//Add variables to the new RITMs
		addVariable(sysID, v_integration_status, current.variables.v_integration_status,1);
		addVariable(sysID, v_db_cat, items[i],2);
	//Start the workflow on all the new RITMs
	startWf(current.request);
function addVariable(ritm,varID,value,order) {
	var variable = new GlideRecord('sc_item_option');
	variable.initialize();
	variable.item_option_new = varID;
	variable.value = value;
	variable.order = order;
	var sysID = variable.insert();
	var itemm2m = new GlideRecord('sc_item_option_mtom');
	itemm2m.initialize();
	itemm2m.request_item = ritm;
	itemm2m.sc_item_option = sysID;
	itemm2m.insert();
function startWf(request) {
	ritm.addQuery('request',request);
	ritm.addQuery('sys_id','!=',current.sys_id);
	ritm.addNullQuery('context');
	ritm.query();
	while (ritm.next()) {
		ritm.setForceUpdate(true);
		ritm.update();
Brad Bowman
Mega Patron
Hi Ravish,
var cilist=[];
var ritmsysid = '';
else{
		ritm.initialize();
	itemm2m.insert();
	ritm.query();
		ritm.update();
thanks, Brad. just what we were looking for.
You are welcome.
DS14
How would you avoid running RUN SCRIPT section for the workflows that got triggered for rest of the RITMs which we have generated from current workflow only?
