Auto numbering through business rule
Siri8
How to write a script for auto numbering records through business rule.I have written below script but it is not triggering.
var gr= new GlideRecord('table_name');
gr.orderByDesc('field_name');
if(gr.next())
var num= gr.field_name;
var str= num.substring(3);
var str_i = parseInt(str);
str_i++;
gr.num="CI"+str_i;
Can you please suggest me
Try below in background script before updating the same in business rule. Also, your business rule is on which table & when it is executing makes difference.
var gr= new GlideRecord('incident');
gr.orderByDesc('number');
if(gr.next())
var num= gr.number;
gs.print(str);
var str_i=Math.floor(str)+1;
gs.print(str_i);
gr.num="CI"+str_i;
gs.print(gr.num);
Let me know until what step you get values printed properly in background script.
Jaspal Singh
if(gr.next())
var num= gr.number;
gs.print(str);
gs.print(str_i);
gr.num="CI"+str_i;
gs.print(gr.num);
Jaspal Singh
Geetanjali Khy2
Mega Guru
Try with adding gr.update() at the end.
You can refer below link it will help,
https://community.servicenow.com/community?id=community_question&sys_id=dc764fe1db1cdbc01dcaf3231f96...
Kindly mark the answer as Correct and Helpful if this answers your question.
Thank You.
Geetanjali Khyale
I have added gr.update(); but it is not triggering the number
