auto Populating the values in a form using glideajax and script include
Vijay8
Giga Contributor
I have a requirement to auto populate the field values (email, mobile, manager, department) when I change the user Using script include and glide ajax
I tried the script below but not working fine
please help
Client script onchange
var userselected = g_form.getValue('u_user');
var userdetails = new GlideAjax('global.userDetailsUtil');
userdetails.addParam('sysparm_name', 'getUserDetails');
userdetails.addParam('sysparm_userselect', userselected);
userdetails.getXMLAnswer(function(response) {
var userObj = JSON.parse(response);
g_form.setValue('u_mobile', userObj.contactNo);
g_form.setValue('u_department', userObj.department);
g_form.setValue('u_email', userObj.email);
g_form.setValue('u_manager', userObj.manager);
Script include
var userDetailsUtil = Class.create();
userDetailsUtil.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getUserDetails: function() {
var uerObj = {};
var gr= GlideRecord('sys_user');
if(gr.get(this.getParameter('sysparm_userselect'))){
userObj.contactNo = gr.getValue('mobile_phone');
userObj.manager = gr.getValue('manager');
userObj.email = gr.getValue('email');
userObj.department = gr.getValue('department');
return JSON.stringify(uerObj);
type: 'userDetailsUtil'
Ashutosh Munot1
Use this one:
Client script:
function onLoad() {
    var getEmailaddr = new GlideAjax('HelloWorld');
    getEmailaddr.addParam('sysparm_name', 'getJsonBack');
    getEmailaddr.addParam('sysparm_userID', g_user.userID);
    getEmailaddr.getXML(populateField);
    function populateField(response) {
        var obj1 = response.responseXML.documentElement.getAttribute('answer');
        var userObj= JSON.parse(obj1);
Script include:
 var usr = this.getParameter('sysparm_userID');
        var obj = {};
        gr.addQuery('sys_id', usr);
        if (gr.next()) {
        obj['contactNo']= gr.mobile_phone.toString();
	obj['department'] = gr.department.toString();
obj['manager'] = gr.manager.toString();
obj['email'] = gr.email.toString();
var dept = JSON.stringify(obj);
return dept;
Ashutosh
Jaspal Singh
Mega Patron
Hi Vijay,
Can you use below in script include
var useris=this.getParameter('sysparm_userselect');
gr.addQuery('sys_id',useris);
if(gr.next())
//if(gr.get(this.getParameter('sysparm_userselect'))){
Chander Bhusha1
Hi Vijay,
In getXMLAnswer it will return only one value that is anwer here you need object so replace the client script with this code.
And the userobject is not used correctly in script include
Use getXML to get the answer
Update the client script as below:
userdetails.getXML(populate) ;
function populate(response) {
var userObj = JSON.parse(answer);
And in the scirpt include you have to use the parameter value as well.
var uerObj = {};
gr.get(this.getParameter('sysparm_userselect'));
return JSON.stringify(userObj);
Mark helpful and correct if it helps
CB
Perfect, Excatley what I needed
Working fine
Thank you
Hi Vijay,
If it resolved you question then can you please mark my response as correct and helpful so that others can refer this solution in future.
It will move this to solved question queue.
CB
