Automate Post on TASK
tmccasland
Is there a way to select tasks assigned to me and post a question to the requestor?
Then you can use the template bar for the same.
Was this answer helpful?
Please consider marking it correct or helpful.
Your feedback helps us improve!
Thank you!
Amit Gujrathi
tmccasland
I asked my permissions to be update for creating templates and now it works Thanks Amit
