Automatically clear values in several fields when one field is cleared
Debbi L
I have a form that, in part, uses four related fields to identify where a piece of hardware is located, and what type it is. I've written a client script that will clear all four fields when one (business_unit) is cleared.
Script Type = onChange
    if (isLoading) {
    g_form.setValue('district', '')
    g_form.setValue('area', '')
    g_form.setValue('structure_type', '');
This works exactly as it's supposed to. Because you can only query one field in a client script, I've written additional scripts on district, area, and structure_type fields. They mirror the original script, only changing the setValue field names. As you can imagine, once I've done that, it's a race to see which script works (or doesn't).
I receive this error if I activate any of the addition scripts:
onChange script error: RangeError: Maximum call stack size exceeded function (){var o=i(m,arguments);return l.apply(n,o)}
Not much of a surprise, as I should be able to find some way to do this in a single script. Therein lies my challenge - I have no idea where to start. Please help?
Debbi
I think you might be hitting an infinite loop. Try adding (for each variable you're trying to update in each script):
if(g_form.getValue('business_unit')!=''){
g_form.setValue('business_unit','');
You're welcome!
