Autopopulate number using options
User_267
So there are 2 fields in a catalogue item- one is Name and other is code.
Name is select box type. So it has multiple options like Ai, Dm, dj, gu, ji, kl, nv.
So when someone selects ai or DM or DJ then it needs to populate 78 number in Code field.
And if someone selects ji ,gu, kl ,then it needs to popoulate 45 number in Code field.
How to do this using client script
2 ACCEPTED SOLUTIONS
Danish Bhairag2
Tera Sage
Hi @User_267 ,
You need to write an onChange client script on Name field.
Pls try this code: use proper backend names for name & code field
    // Get the selected value from the Name field
    var nameValue = g_form.getValue('name');
    // Set the Code field based on the selected Name value
    if (nameValue == 'ai' || nameValue == 'AI' || nameValue == 'DM' || nameValue == 'dj') {
        g_form.setValue('code', '78');
    } else if (nameValue == 'ji' || nameValue == 'gu' || nameValue == 'kl') {
        g_form.setValue('code', '4
5');
Danish
    if (newValue == 'DM' || newValue == 'DJ') {
    } else if (newValue == 'ji' || newValue == 'gu' || newValue == 'kl') {
        g_form.setValue('code', '45');
else if (newValue == 'au' || newValue == 'DG' || newValue == 'hj') {
        g_form.setValue('code', '67');
@User_267 ,
U can add one more else if condition to it.
Danish
