Avoid attachments less than 10kb to get attached to incidents received via reply email to servicenow
Debasis Pati
Hello Everyone,
When servicenow receives emails as reply we have a inbound email action it by default oob attaches the attachments to the target incident/record .
Now we wanted to avoid less than 10kb files to get attached to the target record.
for images to avoid less than 10kb we have oob property "glide.email.inbound.image_sys_attachment.filter.minimum_bytes" but what about other file types how we can avoid that what ever attachments are coming in emails?
@Ankur Bawiskar any suggestions?
Debasis
@Debasis Pati
yes you can try to use that
Did the approach I shared using BR on sys_journal_field work for you?
21 REPLIES 21
Hello @Ankur Bawiskar ,
Even i do not write the copy logic it always copies the attachments to the target incident.
also with your advise i have updated my below script but it is copying everything
gs.include('validators');
if (current.getTableName() == "incident") {
    var gr = current;
    gr.comments = "reply from: " + email.origemail + "\n\n" + email.body_text;
    gr.update();
    // Get attachments from the current email
    var emailAttachments = new GlideRecord('sys_attachment');
    emailAttachments.addQuery('table_name', 'sys_email');
    emailAttachments.addQuery('table_sys_id', email.sys_id);
    emailAttachments.query();
    while (emailAttachments.next()) {
        if (emailAttachments.size_bytes >= 10240) {
            // Copy to incident only if size >= 10 KB
            var attachment = new GlideSysAttachment();
            attachment.copy('sys_email', email.sys_id, 'incident', gr.sys_id);
            gs.log("Skipped small attachment: " + emailAttachments.file_name + " (" + emailAttachments.size_bytes + " bytes)");
without copying script:
    var gr = current;
    gr.update();
in both the scenarios attachments are getting copied oob to the target record irrespective of i do write the copy logic in my inbound action.
@Debasis Pati
then you can use after update business rule on incident table and identify if the comments got changed and starts with reply from:
If yes then iterate and determine which file is less and delete from sys_attachment
OR
Another way is
-> after insert BR on sys_journal_field with condition as this
-> then iterate sys_attachment and handle the deletion logic
@Ankur Bawiskar ,
Just out of curiosity can i write after business rule on after insert and directly i can put when to run conditions as source as inbound email and attctment.size_bytes less than 10240 and then in script get current.attachment.sysid then glide to attachment table and dete the attchment?
can i do this to achieve?
@Ankur Bawiskar ,
@Debasis Pati
Did the approach I shared earlier work for you?
