08-18-2020 01:39 AM
Good Morning,
Please can someone advise... i need a background script to force two CHG records to the state Implement. We have discovered a fault within the change workflow and whilst we get that sorted.. we need to manually force a couple of changes to "implement" so we can proceed with them.
Advise/the script we need to run... would be much appreciated.
As you can see.. i am unable to change the state from the list view (or the form view)
thanks again!
Change Management
08-18-2020 01:56 AM
As per OOB normal change state model , change can we move from authorize to schedule/cancel states only. .
See 'ChangeRequestStateModel_normal' script include.
So, you need use setWorkflow to false before running the script in backgroud or else business rule will stop doing that. Try below script:
var gr= new GlideRecord('change_request');
gr.addEncodedQuery("numberINCHG0030712,CHG0030714");
while(gr.next()){
gr.setWorkflow(false); //prevent running business rule
gr.state='-1';//implement state
gr.update();
Hope this helps!
If I have answered your question, please mark my response as correct and/or helpful.
Suseela P.
08-18-2020 02:21 AM
Glad that you got the approach.
Did you mistakenly mark other answer as correct?
As I see same/similar script was provided before from my end.
Please mark appropriate reply as correct and helpful to help others with the same response find the answer more quickly.
