Barcode Scanning for Asset Management
RonHolton
Kilo Explorer
Has anyone incorporated a Barcode Scanner into ServiceNow? I am hoping to be able to create a inventory view that does the following:
1. Able to select a Stockroom and Status.
2. Scan the Barcode of a laptop and have it automatically update the devices Stockroom and Status.
3. After the Barcode is read, automatically insert or update and be ready for the next scan.
and/or
1. Create a input page that has a field that a Barcode scan would insert and new.
The Barcode Scanner can return either a "Return" or "Tab" after scan. Just can't get the record to update/insert with that action.
Thanks in advance...
Ron
13 REPLIES 13
That is awesome! You did a really nice job putting this together.
Keep up the great work!
Hi Geoff,
Can you share the details with me.
my id is chandra.bose24@gmail.com
Thanks a lot in advance.
Chandra
is there any specific kind of plugins to be activated?
can we not perform integration without bar code software?
No special plugins; we just developed the code ourselves. No "bar code software" was required, just a scanner that could read the bar codes. Originally developed for the HP Dolphin scanners, we have since changed to using   iPhones with connected hand held bluetooth scanners.
tifanny
Kilo Explorer
I have ever used this barcode scanning tool and you may have a try. It supports high-speed and accurate barcode scanning.
