Barcode Scanning for Asset Management
RonHolton
Kilo Explorer
Has anyone incorporated a Barcode Scanner into ServiceNow? I am hoping to be able to create a inventory view that does the following:
1. Able to select a Stockroom and Status.
2. Scan the Barcode of a laptop and have it automatically update the devices Stockroom and Status.
3. After the Barcode is read, automatically insert or update and be ready for the next scan.
and/or
1. Create a input page that has a field that a Barcode scan would insert and new.
The Barcode Scanner can return either a "Return" or "Tab" after scan. Just can't get the record to update/insert with that action.
Thanks in advance...
Ron
13 REPLIES 13
jboeckler
Kilo Explorer
I know this is an old post however just in case others are interested, we are a ServiceNow partner and have been providing IT Asset Management and Barcode/RFID Scanning solutions to SeviceNow customers for a while now.   We have a platform that allows you to easily build native barcode scanning applications and extend the power of the ServiceNow system that works both online and offline on all major of devices iOS/Android/Windows Mobile/BlackBerry.   Let us know if you are interested or check out our website for more information.
Justin Boeckler
http://mobilereach.com/
wjamb
Ron,
I see that this is an old post and this is my first post to the ServiceNow Community, but just wanted to shamelessly plug CG4 Asset Tracking.   We offer off-the-shelf asset tracking software.   We have been doing this for over 14 years.   We have been supporting ServiceNow customers for almost two years now.   Our integration is certified with ServiceNow:   ServiceNow Share   We provide all the functionality you asked for and then some.   I watched the videos of the work Geoff did and I like the work he showed.   Those are great.   If you have not already got your asset tracking barcode needs taken care of, take a look at our website https://cg4assettracking.com or feel free to contact me.
Will Barrowes
CG4 Asset Tracking
will.barrowes@cg4.com
801 675-5172 x104
tomwatson
Kilo Expert
AMI AssetTrack provides barcode asset tracking, is available from the ServiceNow store and is built completely within the ServiceNow platform.   No external third party server is required.
Download a free trial from the ServiceNow store and receive, track, audit, and dispose hardware assets in minutes.
Supports barcode and RFID scanning using all device types including smartphones, rugged scanners, RFID readers.   It's customizable, scalable, and supported across all recent ServiceNow versions.   You don't need to build and support this yourself.
Learn more here: AssetTrack ® 4 IT Asset Tracking Solution for ServiceNow
Cheers,
Tom Watson
President & CEO
http://amitracks.com
I was looking at your video, question how do you track (check in, consume) consumables in ServiceNow?
thanks
Jesus Reyes
