Business Rule not triggering on Insert, but working on Update
02-24-2025 09:46 PM
Trying to update field on task on insertion but it is working only on update.
Incident Management
02-24-2025 10:39 PM
02-24-2025 10:51 PM
I tried to replicate your scenario in my instance. I took Company Name, and it should be set to the new custom field Company Name.
AFTER: Insert/Update
If it helped, please mark it as helpful!
thanks!
02-24-2025 10:54 PM
My BR is in scoped application, is it impacting?
02-24-2025 11:01 PM
I don't think so
While creating a record in the Indicator Task table you have to check that the Indicator field should not be empty. I believe the Indicator field is a reference field, so in the indicator form the Entity field should not be empty and again Entity is also a reference field, so the Name field in Entity form should not be empty
Please check the above conditions!
thanks!
02-24-2025 10:47 PM
Would you mind closing your earlier questions by marking appropriate response as correct?
Members have invested their time and efforts in helping you.
