Calculate days between two dates in portal
Sowmya20
I have requirement to display number of days between two dates in portal.
Example: Start Date :28-08-2023
                End Date: 30-08-2023
No.of Days need display: 3
Please help.
Sowmya
11 REPLIES 11
Hi @Sowmya20 ,
use below script
1. create onchange catalog client script on end date and UI type should be all
	var ga=new GlideAjax('GetDays');//script include name
	ga.addParam('sysparm_name','getNoofDays');//function name
	ga.addParam('sysparm_start_date',g_form.getValue('start_date'));//passing start date to server
	ga.addParam('sysparm_end_Date',newValue);
	ga.getXMLAnswer(setDays);
	function setDays(response){
		var daysdiff=parseInt(response)+1; //covert to int and add 1
		g_form.setValue('no_of_days', daysdiff); //add your variable name
Refer below
2. Create Script include and check client callable
var GetDays = Class.create();
GetDays.prototype = Object.extendsObject(AbstractAjaxProcessor, {
	getNoofDays: function() {
		var start = this.getParameter('sysparm_start_date'); //Passing the start date from the client
		var end = this.getParameter('sysparm_end_Date'); //Passing the end date from the client
		var startDate = new GlideDateTime(start);
		var endDate =new GlideDateTime(end);
		var duration1 = gs.dateDiff(startDate.getDisplayValue(), endDate.getDisplayValue(), true);
		var days=duration1/86400;
		return days;
	type: 'GetDays'
Refer below
Result:
If it helps please click Accept as Solution/hit the Thumb Icon.
ServiceNow Community MVP 2024.
Pavankumar
Pavankumar_1
Mega Patron
Hi @Sowmya20 ,
If your got the resolved then close question by Accepting the solution then only this post will be useful for other users.
Pavankumar
