‎12-27-2017 08:55 AM
I want a field to display the difference between two times in minutes.
Eg: Business Duration = 136
Incident Management
‎12-27-2017 11:00 AM
Hello Santhana
Please try below. g_form doesnot work server side
(function calculatedFieldValue(current) {
var dateString1 = new GlideDateTime(current.begin); //make sure variable name is begin
var dateString2 = new GlideDateTime(current.end); // make sure variable name is end
var diffSeconds = gs.dateDiff(dateString1, dateString2, true);
diffMins = diffSeconds/60;
return Math.round(diffMins); // return the calculated value
})(current);
‎12-27-2017 10:33 AM
‎12-27-2017 10:34 AM
Ah, remove the semicolon and it'll work.
‎12-27-2017 10:37 AM
‎12-27-2017 10:35 AM
Do you need to capture the result in separate custom field?
Yes.
