Called script include using reference qualifier
GBS
called below script in a reference qualfier while calling passed a parameter but the value not getting pass script include function
Reference qualifier: javascript:newCIvalueretrieve().getCis(current.variables.name_of_application_service_you_want_to_map):
Script Include: var Civalueretrieve = Class.create();
initialize: function() {},
getCis: function(parentId) {
var parentIdValue "parentId;
gs.log("parentId sai testing" parentIdValue);
var relations = new GlideRecord('cmdb_rel_ci');
relations.addQuery("parent", parentIdValue);
relations.query();
var ciData [];
while (relations.next()) {
var cis new GlideRecord(cmdb_ci");
cis.addQuery("sys_id', relations.child.sys_id);
cis.query();
if (cis.next()) {
ciData.push(cis-getuniqueValue());
var strQuery new ArrayUtil().unique(ciData);
return "sys_idIN” + strQuery;
type: 'CIvalueretrieve
@GBS
then in that list collector variable you should give variable attributes so that the ref qualifier works
ref_qual_elements=name_of_application_service_you_want_to_map
add that in variable attributes
Also don't use gs.log(). use gs.info()
14 REPLIES 14
Hi Ankur,
I have similar kind of issue, where I have applied reference qualifier on List collector. And the variable type which I passed is reference.  The reference field value is passing as empty while calling the script include function.
I have a similar issue, where
Please share on what variable type the ref qualifier is applied - List collector
Also share what's the variable type for "name_of_application"? - Reference
Where the value is not getting pass while calling the script include.
@Ankur Bawiskar the ref qualifier is applied on the List collector variable type and the variable type of "name_of_application_service_you_want_to_map" is a Reference
@GBS
@Ankur Bawiskar
Can we set default values to list collector field? based on the other reference field
