Can I set a Reference Qualifier Condition in a Catalog Client Script?
Joe Weisiger
Giga Expert
I am creating multiple catalog items which all use a shared variable set.  I am looking for a way to set a Reference Qualifier Condition via a Catalog Client Script.  Is this possible and if so how do I code it?
Thank you,
Joe
Hey,
sorry, my bad - add after line 17 one more "}" - the entire method is not actually enclosed hence we get this error.
Joro
P.S. Sorry for the delay - my actual email is not the one pointed in my account so I dont get notifications (and I cant change it sadly)  😞
16 REPLIES 16
Hi Joro,
I don not actually see literal example in my code above.
Probably, i mislead you by only pasting one function form actual code.
Please let me know if i missing something.
Here I am using same approach as you mentioned in your answer - a common Script Include class:
/*jshint esnext: true */
var CIQualifier = Class.create();
CIQualifier.prototype = {
//methodPerCatalogItems
	type: 'CIQualifier'
CIQualifier.filterForRequest = function(requestId, currentObj) {
var instance = new CIQualifier(currentObj), filter = "";
var  configurationVerification = "1fc0c8191360e70076dcb3776144b032",
		zoning = 'cc35c6133777b100b94d27d2b3990ea6',
                move = '2a4526d30f1331001820e388b1050e0b',
switch(requestId.toString()){
		case configurationVerification:
			filter = instance.configurationVerificationCollector();
			break;
		case zoning:
			filter =  instance.zoneEquipQualifier();
			break;
	return filter;
entire g_form  is not needed so we can pass the actual object of interest as param to the method
That is true, but if you have often requirements change
I prefer all my asset qualifiers looks as
javascript:CIQualifier.filterForRequest(current.cat_item, current);
and fully have logic moved into  CIQualifier.
This give no redundant modifications of variable record + all qualifier changes are store and review  centralized.
this article worked for me:
How to modify Reference Qualifiers with Catalog Client Scripts – ServiceNow – ServiceNow Think (word...
and this is the onChange client script:
var resetFilter = 'active=true^nameISNOTEMPTY^emailISNOTEMPTY^EQ';
var dynamicFilter = g_form.getValue('your other text var holding encoded query').toString().trim();
var gg = g_list.get('your ref var name'); // GlideList2 object
gg.setQuery(newValue == '' ? resetFilter : dynamicFilter);
