Cancellation of a Problem
Shruthi8
I have a requirement to Cancel a problem when it is in New State.
Is it possible to cancel a problem with New state without deleting it?
Thanks in advance
eumak
Hii,
You can achieve this via writing a BR on the specific condition.
Hope it will help you.
Cheers..!
Tushar
Mark it as helpful or correct, If Applicable
Cheers..!
Happy Learning:)
Tushar
Anshu_Anand_
You can use BR on insert/update in problem table
When to run:- state is new
action:- state to closed/resolved or any choice up to your requirement.
Action
Please mark the answer as correct if its helpful
Anshu
Ankur Bawiskar
you can create UI action on problem table and show when state is New
UI Action Condition:
current.state == 101
Script:
current.state = ''; // give choice value for cancel
current.update();
