Catalog client Script for field visibility
mayurbaligar
        // return;
var tstate=g_form.getValue(state);
if (tstate == '-5'){
g_form.setVisible('u_priority_reason', true);
why isnt the above working?
- i have made u_priority_reason hidden onload
- i want To make it visible when the dropdown value of state is -5
9 REPLIES 9
still no luck!
i have put the alert in place and its not triggering. can you try hiding the field?
couple of things to highlight:
- it is a catalog client script
- for a particula rcatalog item
- applies on catalog task as well
latest Script:
alert('CHECK CHANGE ALERT');
var tstate=g_form.getValue('state');
alert('tstate>>>'+tstate);
LadySNWizard
is the first alert coming?
No, it is not!
i have another script for hiding the same field onLoad which is working fine.
but am trying to make the same field visible onChange it is not working!
LadySNWizard
Try changing the order of the Script. Also check if there is any UI Policy for the same field. That might be the issue.
vmeesala
Giga Contributor
check what value you are getting from state, Use log see that
g_form.setDisplay('u_priority_reason', true);
