catalog item build - Flow designer
dassan
I am developing a flow for a catalog item for an application install request. In the flow designer the build is done till the Catalog task item which is assigned to IT team.
Need help in understanding what logic to apply post the catalog task creation, how to close the flow & can I add a notification trigger at the same point.
Sanyo
2 ACCEPTED SOLUTIONS
AndersBGS
hi @dassan
After task completion I would make an update of RITM to set state and other fields to resolved. Basically, further processing depends on your work process and other configuration.
Just add another "update record" action after this step to close the RITM and/or any other logic you want to implement.
Dr Atul - LNG
Hi @dassan
You need to set the/stages to the same value.
You can pick any OOTB flow to understand this.
https://www.servicenow.com/docs/r/build-workflows/workflow-studio/add-stages.html
https://youtu.be/lvbgaRpQsUc
https://youtu.be/KS0hzjtsTJY
Day 19 - Flow Designer Actions (ServiceNow) This session focused on advanced usage of Flow Designer in ServiceNow, including working with catalog variables, notifications, waiting conditions, record lookups, loops, integrations, stages, and debugging flows. Key Topics Covered 1. Using Catalog ...
Day 18: ServiceNow Flow Designer This session focused on Flow Designer, ServiceNow's modern automation tool used to create workflows such as approvals, task creation, notifications, and integrations. The instructor explained why Flow Designer has replaced the legacy Workflow engine and ...
Ankur Bawiskar
@dassan
it all depends on your business requirement i.e. what should happen after catalog task creation
Does your business require email to be send once Catalog task is closed? -> If yes then your flow can wait till catalog task closure using the Wait checkbox and then use "Send Email" flow action to send email
what's your exact requirement?
dassan
Hello Ankur,
Thank you for your inputs.
My query is how can I determine my catalog task is closed.
@dassan
that Wait checkbox means your flow will wait till Catalog task is closd (Closed Complete, Close Incomplete etc)
After that step you can check the state of your catalog task and accordingly send the email
