Does "Set default knowledge field values" → Article Body support HTML formatting?
Priya Solanki
I am trying to configure a default Article Body for a Knowledge Base using the Set default knowledge field values feature.
Navigation:
Knowledge Base → Set default knowledge field values → Article Body
When I select Article Body, a field labeled "Enter text in HTML format" appears.
My expectation was that this field would accept and preserve HTML formatting, so I entered HTML containing:
     1. Images
    2. Headings
    3. Bullet points
    4. Inline styles (font family, font size, colors)
However, when I create a new Knowledge Article using this Knowledge Base, the HTML formatting is not applied as expected. Styling such as custom fonts, colored bullets, and some inline formatting is ignored.
 Is this a known limitation or expected out-of-the-box behavior? If HTML formatting is not supported here, what is the recommended approach for populating a formatted default Article Body (including images, bullet points, and styling) for all articles created in a specific Knowledge Base?
Rafael Batistot
Mega Patron
Hi @Priya Solanki
May you try to use Knowledge Templates
https://www.servicenow.com/community/servicenow-ai-platform-forum/how-to-create-design-templates-for...
If this response was helpful, please mark it as Helpful and, if applicable, as Correct.
This helps other users find accurate and useful information more easily
