07-09-2026 05:11 AM
I am developing a flow for a catalog item for an application install request. In the flow designer the build is done till the Catalog task item which is assigned to IT team.
Need help in understanding what logic to apply post the catalog task creation, how to close the flow & can I add a notification trigger at the same point.
Sanyo
07-09-2026 11:23 AM
hi @dassan
After task completion I would make an update of RITM to set state and other fields to resolved. Basically, further processing depends on your work process and other configuration.
Best regards
Anders
Rising star 2024
MVP 2025
07-09-2026 11:43 AM - edited 07-09-2026 11:43 AM
Just add another "update record" action after this step to close the RITM and/or any other logic you want to implement.
CSA | CAD | DF | DISCO | ITIL4
07-09-2026 11:23 AM
hi @dassan
Best regards
Anders
Rising star 2024
MVP 2025
