change of assignment group when conditions are met in incident.
Atchutaram
Hi Everyone,
When business service is cisco and channel is alert and alert severity is major, assignment group should be changed from servicedesk to netwrok team. So i have written a on change change of business service field client script.
    // Exit early if the form is loading or the new value is empty
    // Get values from relevant fields
    var service = g_form.getValue('business_service');
    var channel = g_form.getValue('contact_type');
    var alertsev = g_form.getValue('u_alert_severity');
    // Check all conditions
    if (
        service == 'c6c44a961bd88d90e6966534b24bcb91' &&
        channel == 'alert' &&
        alertsev == 'major'
        // Set assignment group if all conditions are met
        g_form.setValue('assignment_group', '850ae8e9db096b80dd1662eb0b961945');
This is not working and group is not changing, can you let me know how can i correct this?
@Atchutaram
did you add alert and see if it gave correct value and went inside the IF?
Chaitanya ILCR
Giga Patron
Hi @Atchutaram ,
are all those fields available on the form?
if not configure form layout and add those fields to the form
You can use the UI policies too. Add the condition and in the value add the sysid of the group in the UI policy action
Chaitanya
AndersBGS
Hi @Atchutaram ,
Can you please share a snip of your full configuration? The script should work according to how you have stated it above.
Best regards
Anders
Rising star 2024
MVP 2025
