Check if order guide or not in catalog client script
Renu9
i am having a variable in variable set which is in order guide and also in the catalog items which are in rule base
The variable is a dropdown with 2 choices (choice A, choice B)
If the request is raised from catalog item then only choice A should be visible
if the request is raised from order guide then both choices should appear
how to check if the request is raised from order guide or from stand alone catalog item in catalog client script
is there any method to check for order guide
pl guide
sujitha16
@Renu9 Did you check using the below syntax?
function onLoad() {
    var isOrderGuide = g_service_catalog.isOrderGuide();
    if(isOrderGuide) {
        g_form.addInfoMessage("We're part of an order guide!"); //You can hide the variables accordingly using the syntax
        g_form.addInfoMessage("We are not a part of an order guide."); //You can hide the variables accordingly using the syntax
Please mark this as helpful and accept it as a solution if this resolves your query.
Sujatha V.M.
sujitha16
function onLoad() {
    if(isOrderGuide) {
Sujatha V.M.
