Clear list collector selected values when some field is changed in Service Portal AND Desktop
Baggies
Clear list collector selected values when some field is changed in Service Portal.
 When I change the value of one variable, a choice list, on a catalog item, I want the values from a list collector all cleared out. I have managed to achieve this with help from this forum. Trouble is, I have had to create  one script for the portal, and one for desktop view. here they are list below. Can I achieve the same results with one script only which will work in Portal  and desktop views? "add_user_to_group" is my list collector name. Many thanks. Mark S.
Portal script:
Works in portal
Name:
Clear values on change
Type: onChange
UI Type: Mobile/Portal *** THIS IS IMPORTANT *****
var collectorName = 'add_user_to_group'; //Name of your list collector.
var myListCollector = g_list.get(collectorName);
var selectedOptions = g_form.getValue(collectorName).split(',');
if((selectedOptions != "") && (selectedOptions.length > 0)){
//Remove items
var index = 0;
for (var i = 1, leng = selectedOptions.length+1; i < leng; i++){
myListCollector.removeItem(selectedOptions[selectedOptions.length-i]);
index++;
alert(" ** changed in portal ***");
Works in classic view
Name:
Type: onChange
UI Type: Desktop *** THIS IS IMPORTANT *****
var listCollectorName = 'add_user_to_group'; //Name of your list collector.
var leftBucket = gel(listCollectorName + '_select_0');
var rightBucket = gel(listCollectorName + '_select_1');
var selectedOptions = rightBucket.options;
var selectedIDs = [];
for(var i = 0; i < selectedOptions.length; i++){
//Check for the item to add here based on sys_id
selectedIDs.push(i);
//var value = selectedOptions[i].value;
//rightBucket.remove(value);
// var lefBucket = gel(listCollectorName + '_select_0');
//leftBucket.add(value);
moveSelectedOptions(selectedIDs,rightBucket,leftBucket,'--None--');
sortSelect(leftBucket);
var leftOptions = leftBucket.options;
for(var j = 0; j<leftOptions.length; j++){
var value = leftOptions[j].innerHTML;
if(value == '--None--'){
leftBucket.remove(j);
alert(" ** changed in CLASSIC view ***");
Mike Patel
Tera Sage
Change type to all and use below script to combine it.
	try{
			//Remove items
			var index = 0;
				index++;
	catch(err){
thomas_wright1
Giga Contributor
Mike,
This is interesting but wondering if how I have my variable list collector setup causes this not to work either way.
I have a catalog item that displays in a UI page.  I have a variable set that contains a list collector. If I set the UI type on the variable, i and use that code I get a console error of g_list is not defined.  If I change the UI type to desktop, I get gel is not defined.
Is there something special that I need to do on the UI page side so that it will know what either one is?
Tom
