Options
04-11-2022 01:49 AM
hi all
i have a field name(u_string_1). i want to clear the field value in Business rule i.e server side. can anyone tell me what is the syntax like current.?
Thank you.
Options
04-11-2022 01:52 AM
I assume you are using before insert/update BR
simple syntax
current.u_string_1 = '';
OR
current.setValue('u_string_1','');
Options
04-11-2022 01:52 AM
simple syntax
OR
