Client Callable Script include issue as script filter in reports
yashu1995
Mega Guru
We have a requirement to generate report to revoke ITIL licenses of users.
in that report the
conditions are Logged in at or before Last 30 days. Few Exception Users & Few Exception Groups.
I created a report on sys_user table
To get data i have written client callable script include:
if i add static values in script like direct 'itil' and '30' in scripting its working and data is coming in report.
When i call the value using property no data is showing up in report. Kindly help me.
Ankur Bawiskar
gs.getProperty() won't work in client callable script include when it's called from a reporting filter condition as it will be executed on client side.
I have faced similar challenge earlier and was surprised to know this drawback.
Instead you can query sys_property table with that property name and get the value.
Check this link which talks the same which all classes are not allowed
Script sandbox property
Ankur Bawiskar
@yashu1995
Hope you are doing good.
If my response helped please close the thread by marking appropriate response as correct so that it benefits future readers.
Chandu Telu
May I know why you used the client callable script include , You can use the direct script include for this
If you create this script include for only this functionality, you can inactivate this and create a new one??
Chandu Telu
Please Mark ✅ Correct/helpful, if applicable,
