Client Script for adding values from 3 fields and populating it on other field
sachinshivakuma
Mega Contributor
I need some help scripting on adding values from 3 fields and populating them in a new field.
Thanks in advance.
19 REPLIES 19
Thanks Chuck, helpful.
Sharique Azim
Hi Sachin,
Although your requirement is not clear , but I would answer to best of my understandings.
store the values of the fields in some variable,
var xyz=''; // empty string
var a=g_form.getValue('field_1');
var b=g_form.getValue('field_2');
var c=g_form.getValue('field_3');
xyz +=a+b+c;
vg_form.setValue('field_4',xyz);
I hope this helps.
Shariq
Hi Shariq,
    I'm using the same script to calculate the value of a+b and get total sum value in the single line text box. This script is not working for me. can you help me
I'm using 2 select box'es
a Select Box has option yes or no  (Yes value as 10 ; No Value as 5)
b Select Box has option yes or no (Yes value as 10 ; No Value as 5)
I'm using C as a single line text box I need to get the score of what the user selects.
If Select Yes in A; Yes in B;
It should autopopulate C as 10
Please help
Thank you!!
Jim Coyne
I'm assuming you want to update the total field each time one of the 3 fields changes, correct?   This is how you can set things up for the least maintenance:
1. an onLoad Client Script that will declare a function that does the actual calculation
function onLoad() {
    //nothing happens here, but we still need the onLoad block for this to work
function u_calculateTotal(){
  g_form.setValue("u_total", g_form.getIntValue("u_integer1") + g_form.getIntValue("u_integer2") + g_form.getIntValue("u_integer3"));
The getIntValue() function retrieves the value of the input fields as integers so no need to convert them.
2. onChange Client Scripts for each of the 3 input fields
  if (isLoading) {
  //call the shared function to update the total field
  u_calculateTotal();
Thanks Jim! I learned something new today. I wasn't acquainted with g_form.getIntValue(). Good to know.
