Client script in scoped application is not executing the script include
harika26
The requirement is to create the pop up dialog box with all the attachments that the HR case form has when ever the handover checkbox is checked.
I have written the on change client script and called the script include using glide ajax. It is showing all the alerts from client script but not giving any logs from the script include.
Any help is appreciated.
client script
    // var confirm_box = confirm("Confirm Box");
    if (newValue.toString() == 'true') {
        alert("HJ newValue---" + newValue);
        var recordSysId = g_form.getUniqueValue();
        alert("HJ recordSysId---" + recordSysId);
        var tableName = g_form.getTableName();
        alert("HJ  tableName---" + tableName);
        //Initialize and open the Dialog Window
       // var dialog = new GlideDialogWindow("confirm_dialog");
        // dialog.setTitle("Add Attachment to handover"); //Set the dialog title
       //var attach = new GlideAjax('sys_attachments');
        var attach = new GlideAjax('BICheckAttachment'); //BICheckAttachment
        alert("HJ Attach");
        attach.addParam('sysparm_name', 'getAttachmentsFromForm');
       attach.addParam('sysparm_id', recordSysId);
        attach.addParam('sysparm_table', tableName);
        attach.getXML(fill);
        function fill(response) {
          alert("HJ Response-" + response);
            dialog.setPreference("target_sys_id", answer);
            dialog.setPreference("target_table", tableName);
            dialog.setSize(500, 500);
            dialog.render(); //Open the dialog
script include - accessible from all application scopes is selected.
var BICheckAttachment = Class.create();
BICheckAttachment.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
	getAttachmentsFromForm: function()
		gs.info("HJ CHECK IN SCRIPT INCLUDE");
		var answer= [];
		var id = this.getParameter('sysparm_id');
		gs.info("HJ ID--"+id);
		var value = this.getParameter('sysparm_table');
		gs.info("HJ value--"+value);
		var grat= new GlideRecord('sys_attachment');
		grat.addQuery("table_sys_id",id);
		grat.addQuery("target_table", value);
		grat.query();
		while(grat.next())
				gs.info("HJ--grat"+grat.next());
            answer.push(grat.sys_id.toString());
		gs.info("HJ Answer"+answer);
            return 'sys_idIN' + answer.join(",");
    type: 'BICheckAttachment'
End result should be as below - I achieved it once but without changing anything it is not working again. Dont know how it worked earlier
28 REPLIES 28
IT means do we need to create Ui page or Macros instead of client script
They asked me to use macro initially since I was not able to develop macro I used Client script
Sorry I didn't get you.
Can you explain how is showing the popup linked with transferring the case?
In the form, there is a checkbox for attachments and a UI Action Handover
when we click on Handover, the case will be closed and it handovers to incident with some table fields.
when evr we select the attachments check a new pop up box should appear with all the attachments from the case, so the user should be able to remove the unwanted attachments . The remaining attachments need to be saved and should be transferred along with table fields at the same time wheN handover button is selected
then check this link where I have shared solution on how to show attachments on UI page
enhance as per your use-case
https://community.servicenow.com/community?id=community_question&sys_id=0fcadee0dbc048d0feb1a851ca96...
hie can you please check my UI page why it is not showing checkboxes before attachments and remove button in the pop up box
UI page
<?xml version="1.0" encoding="UTF-8"?>
<j:jelly trim="false" xmlns:g="glide" xmlns:g2="null" xmlns:j="jelly:core"
	xmlns:j2="null">
	<j:set var="jvar_target_sys_id" value="${JS:RP.getWindowProperties().get('target_sys_id')}" />
	<j:set var="jvar_target_table" value="${JS:RP.getWindowProperties().get('target_table')}" />
    <j:set var="jvar_attachment_disabled" value="${RP.getWindowProperties().get('attachment_disabled')}" />
    <j:set var="jvar_sc_override" value="${RP.getWindowProperties().get('sc_override')}" />
	<j:set var="jvar_show_link" value="true" />
	<j:if test="${gs.getProperty('glide.ui.disable_attachment_view') == 'true'}">
		<j:set var="jvar_show_link" value="false" />
	</j:if>
	<input type="hidden" id="ni.show_attachment_view" name="ni.show_attachment_view"
		value="${jvar_show_link}" />
	<j:set var="jvar_show_link_popup" value="true" />
	<j:if test="${gs.getProperty('glide.ui.attachment_popup')=='false'}">
		<j:set var="jvar_show_link_popup" value="false" />
	</j:if>
   <!-- Check no_attachment attribute in order to override if necessary. -->
   <g:evaluate var="jvar_no_attachment" jelly="true">
		var gr = new GlideRecord(jelly.jvar_target_table);
		gr.getED().getBooleanAttribute("no_attachment");
	</g:evaluate>
	<!-- Check if attachements are edge encrypted to show Download all only is not edge encrypted. -->
	<g:evaluate var="jvar_attachments_edge_encrypted" jelly="true">
		gr.getED().hasAttachmentsEncrypted();
	</g:evaluate>
	<g:evaluate var="jvar_have_not_available_attachments" jelly="true">
		var count = new GlideAggregate('sys_attachment');
		count.addQuery('table_name', jelly.jvar_target_table);
		count.addQuery('table_sys_id', jelly.jvar_target_sys_id);
		count.addQuery('state', 'not_available');
		count.addAggregate('COUNT');
		count.query();
		count.next() &amp;&amp; (count.getAggregate('COUNT') > 0);
	</g:evaluate>
	<g:evaluate var="jvar_kmfcleprop" jelly="true">
		gs.getProperty('glide_encryption.cle_replatforming_with_kmf');
	</g:evaluate>
	<!-- Store if attachements are edge encrypted for use in javascript -->
	<script>
		var edgeEncryptionEnabledForAttachments = '${jvar_attachments_edge_encrypted}';
	</script>
	<g:evaluate var="jvar_cloudedge_invalid" jelly="true">
		<!-- If attachments are edge encrypted and not edge session -->
		(jelly.jvar_attachments_edge_encrypted == "true") ${AMP}${AMP} !gs.isEdgeEncryptedSession();
	</g:evaluate>
   <!-- Check Users Ability to Attach -->
   <g:evaluate var="jvar_attachrole" expression="gs.getProperty('glide.attachment.role')" />
   <g:evaluate var="jvar_can_write_to_record" jelly="true">
	   (jelly.jvar_sc_override == 'true') ||
	   new AttachmentSecurity().canWriteTarget(jelly.jvar_target_table, jelly.jvar_target_sys_id);
   </g:evaluate>
   <j:if test="${jvar_attachment_disabled == 'true'}" >
        <j:set var="jvar_can_write_to_record" value='false' />
   </j:if>
   <g:evaluate var="jvar_email_client_override" jelly="true">
   		var ret = jelly.sysparm_this_url.startsWith('email_client.do');
   		ret;
   </g:evaluate>
   <!-- Store parent sys_id for use in javascript -->
   <script>
		var attachmentParentSysId = '${jvar_target_sys_id}';
   </script>
   <j:set var="jvar_can_add_attachments" value="false" />
   <j:set var="jvar_can_edit_attachments" value="false" />
   <j:if test="${jvar_email_client_override == 'true'|| jvar_sc_override == 'true'}" >
   		<j:set var="jvar_can_add_attachments" value="true" />
                <j:set var="jvar_can_edit_attachments" value="true" />
   </j:if>
   <j:if test="${jvar_email_client_override == 'false'}">
	   	<j:if test="${jvar_no_attachment == 'false'}">
	   		<j:if test="${jvar_can_write_to_record == 'true'}">
	   			<j:if test="${jvar_session.hasRole(jvar_attachrole)}">
				</j:if>
			</j:if>
		</j:if>
	</j:if>
    <j:if test="${jvar_attachment_disabled == 'true' || jvar_cloudedge_invalid == 'true'}" >
    </j:if>
	<input type="hidden" id="ni.show_rename_link" name="ni.show_rename_link"
		value="${jvar_can_add_attachments}" />
	<input type="hidden" id="ni.show_attachment_popup" name="ni.show_attachment_popup"
		value="${jvar_show_link_popup}" />
	<div id="alert_container"></div>
	<table width="100%" style="table-layout:fixed;">
		<tbody>
			<j:if test="${jvar_can_add_attachments}">
				<tr>
					<td>
						<div class="caption" style="display:none;">
							<span>${gs.getMessage('Choose a file to attach')}:</span>
						</div>
					</td>
				</tr>
				<tr>
					<td>
						<FORM id="sys_attachment" name="sys_attachment" action="sys_attachment.do?sysparm_record_scope=$[jvar_parent_record_scope]"
							enctype="multipart/form-data" method="post"
							onsubmit="return validateAttachment();" target="upload_target"
							style="display: none;">
								<script>$('sys_attachment').style.display = 'block';</script>
							</j:if>
							<input name="attachments_modified" id="attachments_modified"
								type="hidden" value="" />
							<input name="sysparm_sys_id" type="hidden" value="${jvar_target_sys_id}" />
							<input name="sysparm_table" type="hidden" value="${jvar_target_table}" />
							<input name="max_size" type="hidden" value="${gs.getProperty('com.glide.attachment.max_size')}" />
							<input name="file_types" type="hidden" value="${gs.getProperty('glide.attachment.extensions')}" />
							<input name="sysparm_nostack" type="hidden" value="yes" />
							<input name="sysparm_redirect" type="hidden"
								value="attachment_uploaded.do?sysparm_domain_restore=false&amp;sysparm_nostack=yes" />
							<input id="sysparm_encryption_context" name="sysparm_encryption_context"
							<table id="attachmentTable" width="100%" style="table-layout:fixed;" role="presentation">
								<TR class="attachmentRow">
									<g2:set_if var="jvar_td_styles" test="$[GlideMobileExtensions.getDeviceType() == 'm']" true="visibility: hidden; width: 0;" false=""/>
									<td style="$[jvar_td_styles]" id="attachFileCell" colspan="3">
										<input id="attachFile"
											name="attachFile" onChange="checkAndSetAttachButton(); setDeleteButton(this.value); $('attachButton').click();" size="41"
											type="file" multiple="true" style="width: 0.1px;height: 0.1px;opacity: 0;overflow: hidden;position: absolute;z-index: -1;" tabindex="-1">
										<input type="button" title="${gs.getMessage('Attach')}" id="loadFileXml" value="${gs.getMessage('file_attach')}" onclick="document.getElementById('attachFile').click();" > $[SP]$[SP]${gs.getMessage('no_file_chosen')} </input></input>
										<a href="#" class="attachfile-delete" onclick="clearAttachmentField($(this).up().up()); setDeleteButton(this.value);" style="cursor: default;display:none;">
											<img src="images/icons/kb_no_disabled.gif" />
										</a>
										<input style="display:none;" disabled="true" class="attachfile-attach button" id="attachButton" type="submit"
											value="${gs.getMessage('Attach')}" />
									</td>
									<script>document.getElementById("loadFileXml").focus()</script>
									<j2:if test="$[GlideMobileExtensions.getDeviceType() == 'm']">
										<g:requires name="scripts/snm/cabrillo/js_includes_cabrillo.js" includes="true" />
										<td colspan="3">
											<button id="cabrilloAttach" title="${gs.getMessage('Attach')}" size="41">${gs.getMessage('Attach')}</button>
											<script>
											(function($, cabrillo){
												var cabrilloTable = '${JS:jvar_target_table}';
												var cabrilloSysId = '${JS:jvar_target_sys_id}';
												$('#cabrilloAttach').on('click', function saveCabrilloAttachments(event) {
													event.preventDefault();
													cabrillo.attachments.addFile(cabrilloTable, cabrilloSysId).then(
														function(data) {
															var url = $('[name=sysparm_redirect]').val();
															url += "${AMP}sysparm_name=" + data.sys_id;
															$('#upload_target').attr('src', url);
														function(err) {
															console.error("Upload failed", error);
											})(jQuery, snmCabrillo);
											</script>
										</td>
									</j2:if>
								</TR>
								<j:if test="${jvar_kmfcleprop != 'opt_in'}">
									<g2:attachment_encrypt />
								</j:if>
								<TR>
									<td>
										<input style="display:none;" type="button" value="${gs.getMessage('Add Another Attachment')}"
											onclick="addRowToTable()" class="button"></input>
									</td>
								</TR>
							</table>
						</FORM>
					</td>
				</tr>
			</j:if>
			<j:if test="${jvar_cloudedge_invalid}">
				<tr>
					<td>
						<div class="caption">
							<p>${gs.getMessage('The attachments are encrypted and all actions are disabled until you connect to your company network.')}</p>
						</div>
					</td>
				</tr>
			</j:if>
			<tr>
				<td>
					<img style="margin: 6px 3px 6px 3px;display:none;" id="please_wait"
						 src="images/please_wait.gifx" alt="${gs.getMessage('Please Wait')}" />
						<span>${gs.getMessage('Current file attachments')}:</span>
					</div>
				</td>
			</tr>
			<tr>
				<td>
					<FORM action="sys_attachment.do?DELETE" method="post" target="upload_target"
						onsubmit="return startRemoveAttachments()">
						<input name="sysparm_this_url" id="sysparm_this_url" type="hidden"
							value="" />
						<input name="deleted_sys_ids" id="deleted_sys_ids" type="hidden"
							value="" />
							<TR>
								<TD style="white-space:nowrap;">
									<div id="current_attachments" style="display:block">
										<div style="margin-top:4px;">
											<div id="attachment_dialog_list">
														<tbody id="attachment_table_body">
															<j2:set value="false" var="jvar_some_deletable" />
															<g2:attachment_list_by_availability sys_id="${jvar_target_sys_id}"
																table="${jvar_target_table}" available="true">
																<g2:for_each_record file_variable="sys_attachment"
																	var="attachment">
																	<j2:set value="true" var="jvar_have_attachments" />
																	<g2:evaluate var="jvar_checkbox_label">
																		gs.getMessage("Select attachment {0} for removal", sys_attachment.file_name);
																	</g2:evaluate>
																	<j2:set
																		value="$[sys_attachment.encryption_context.getDisplayValue()]"
																		var="jvar_encrypt_context" />
																	<TR>
																		<TD colspan="2" style="white-space:nowrap;">
																			<j2:set var="jvar_can_delete" value="$[sys_attachment.canDelete()]" />
																			<j2:if test="${jvar_can_edit_attachments}">
																			<j2:if test="$[jvar_can_delete]">
																				<input name="sys_id_$[sys_attachment.sys_id]"
																					id="sys_id_$[sys_attachment.sys_id]" title="$[HTML:jvar_checkbox_label]"
																					onclick="setRemoveButton(this);" type="checkbox" aria-label="$[HTML:jvar_checkbox_label]"/>
																				<j2:set value="true" var="jvar_some_deletable" />
																			</j2:if>
																			</j2:if>
																			<input name="Name" type="hidden" value="false" />
																			<input type="hidden" id="$[sys_attachment.sys_id]" class="attachment_sys_id" />
																			<g2:attachment_entry />
																		</TD>
																	</TR>
																</g2:for_each_record>
															</g2:attachment_list_by_availability>
															<j2:set var="jvar_no_attachments_display" value="block" />
															<j2:if test="$[jvar_have_attachments]">
																<j2:set var="jvar_no_attachments_display" value="none" />
															</j2:if>
															<tr id="no_attachments" style="display:none;">
																<td colspan="2">${gs.getMessage("None")}</td>
															</tr>
														</tbody>
														<j2:set var="jvar_show_not_available_header" value="none" />
														<j2:if test="${jvar_have_not_available_attachments}">
															<j2:set var="jvar_show_not_available_header" value="block" />
														</j2:if>
														<td id="not_available_files_header" style="padding-top:10px; display:$[jvar_show_not_available_header]">${gs.getMessage('Potential security risks')}</td>
															table="${jvar_target_table}" available="false">
																var="attachment">
																<j2:set value="true" var="jvar_have_not_available_attachments" />
																</g2:evaluate>
																<j2:set value="$[sys_attachment.encryption_context.getDisplayValue()]"
																<TR>
																			<j2:if test="$[sys_attachment.canDelete()]">
																					   onclick="setRemoveButton(this);" type="checkbox" class="not_available" aria-label="$[HTML:jvar_checkbox_label]"/>
																			</j2:if>
																		</j2:if>
																	</TD>
																</TR>
													</table>
											</div>
													<tr>
														<td>
															<j2:set var="jvar_show_download_all_button" value="none" />
																<!-- Show download all only if the attachments are not edge encrypted -->
																<j2:if test="${!jvar_attachments_edge_encrypted}">
																<j2:set var="jvar_show_download_all_button" value="inline" />
															</j2:if>
																</j2:if>
															<input style="display:$[jvar_show_download_all_button];" id="download_all_button" type="button" class="btn btn-default" value="${gs.getMessage('Download All')}" onclick="downloadAllAttachments()"/>
														</td>
														<td>
															<span id="delete_button_span"
																style="float:right; text-align:right; display:none;">
																<input disabled="true" id="removeButton" class="btn btn-destructive-subdued"
																	title="${gs.getMessage('Remove')}" type="submit" value="${gs.getMessage('Remove')}" />
															</span>
														</td>
													</tr>
												</table>
											</j2:if>
										</div>
									</div>
								</TD>
							</TR>
						</table>
					</FORM>
					<j2:if test="$[jvar_some_deletable]">
						<script>document.getElementById('delete_button_span').style.display
							= "inline";</script>
					</j2:if>
				</td>
			</tr>
		</tbody>
	</table>
	<!-- this is where we send our form submissions so that the dialog stays
		up -->
	<iframe id="upload_target" tabindex="-1" name="upload_target" title="${gs.getMessage('Attachments')}" src="blank.do?sysparm_domain_restore=false"
		style="position:fixed;clip: rect(0,0,0,0);width:100%;height:0;border:0px solid #fff;">$[SP]</iframe>
</j:jelly>
client script
 * Validate the attachments to see if at least
 * one file is attached. Otherwise, show an alert.
 * @returns {Boolean}
function validateAttachment() {
	var form = $('sys_attachment');
	var fileFields = form.select('.attachmentRow');
	for (var i = 0; i < fileFields.size(); i++) {
		if (fileFields[i] && fileFields[i].value != "") {
			setAttachButton(""); //disable
			$('please_wait').style.display = "";
			return true;
	alert("${JS:gs.getMessage('Choose a file to attach')}");
    return false;
 * Does the first attachment input field have a value?
 * If not, use the grey button and change type of cursor.
 * @param value
function setDeleteButton(value) {
	var field = $$('.attachmentRow')[0];
	var text = field.select('input')[0];
	var deleteButton = field.select('a.attachfile-delete img')[0];
	if (!text.getValue().empty()) {
		deleteButton.setAttribute('src', 'images/icons/kb_no.gif');
		deleteButton.up().style.cursor = 'pointer';
		deleteButton.setAttribute('src', 'images/icons/kb_no_disabled.gif');
		deleteButton.up().style.cursor = 'default';
 * If the value passed in is an empty string,
 * set the button to disabled state, otherwise
 * enabled.
 * @param value
function setAttachButton(value) {
  var attachButton = $("attachButton");
  if (value == "")
    attachButton.disabled = "true";
  else
    attachButton.disabled = "";
 * This controls the remove button for all attachments.
 * If there are attachments in the list enable the button.
 * Else keep disabled.
 * @param e
function setRemoveButton(e) {
  var removeButton = gel("removeButton");
  var deletedSysIdsElement = gel("deleted_sys_ids");
  var deletedSysIds = new Array();
  var deletedString = deletedSysIdsElement.value;
  if (deletedString)
     deletedSysIds = deletedString.split(";");
  var thisId = e.name.substring(7);
  if (e.checked) {
    removeButton.disabled = "";
    deletedSysIds.push(thisId);
    var index = deletedSysIds.indexOf(thisId);
    deletedSysIds.splice(index, 1);
    // are there any left checked?
    var inputs = document.getElementsByTagName("input");
    var nonechecked = true;
    var i = 0;
    while(i < inputs.length && nonechecked) {
      if (inputs[i].type == "checkbox" && inputs[i].name.substring(0, 7) == "sys_id_")
        if (inputs[i].checked)
          nonechecked = false;
        i++;
    if (nonechecked) {
      removeButton.disabled = "true";
  deletedSysIds = deletedSysIds.join(";");
  deletedSysIdsElement.value = deletedSysIds;
function startRemoveAttachments() {
  removeButton.disabled = true;
  gel('please_wait').style.display = "";
  var thisUrl = gel("sysparm_this_url");
  thisUrl.value = "attachment_deleted.do?sysparm_domain_restore=false&sysparm_nostack=yes&sysparm_deleted=" + gel("deleted_sys_ids").value;
  return true;
 * Clear and Remove the attachment field that is
 * passed in.
 * @param field_id
function clearAttachmentField(field) {
	fileFields[0].setAttribute('data-position', 'first');
	if (fileFields.size() > 1 && (field.readAttribute('data-position') != "first")) {
		//check if field you are removing has a 3rd column (does it have an attach button?)
		var needToAttachButton;
        var attachButton = field.select('td')[2];
        if (attachButton)
        	needToAttachButton = true;
        //remove the field
		field.remove();
		//if you removed a field with a third column, add an attachbutton onto the new "first" field.
		if (attachButton) {
			var attachButton = new Element('input', {
			   "type": "submit",
			   "id": "attachButton",
			   "disabled": "true",
			   "value": "${gs.getMessage('Attach')}" });
			var td = new Element('td', {align: 'right'}).update(attachButton);
			Element.extend(td);
			form.select('.attachmentRow').first().select('td')[1].insert({'after': td});
	else
		clearFileField(field.select('td').first().select('input').first());
 * Check all attachment input fields. If there is not attachment
 * currently, disable the attachment button, else enable it.
 * @returns
function checkAndSetAttachButton() {
        var validFileCount = 0;
			var field = fileFields[i].select('td').first().select('input').first();
			if (field.getValue() != "") {
				if (window.File && window.FileReader && window.FileList)
					validFileCount += validateSizeandExt(field);
				else
					validFileCount += 1;
        if (validFileCount == 0)
        else
			setAttachButton("true");
function validateSizeandExt(field) {
	var maxSize = (form.max_size && form.max_size.value) ? form.max_size.value : 0;
	var fileTypes = (form.file_types && form.file_types.value) ? form.file_types.value : "";
	var files = field.files;
	var allowedSize = maxSize * 1048576;
    var warningString = "";
	var checkJEXL = true;
	for (var i = 0; i < files.length; i++) {
		if (checkJEXL && isJEXLExpression(files[i].name)) {
			warningString += files[i].name + "${JS:gs.getMessage(' is an invalid file name.\n')}";
		if (files[i].size > allowedSize && allowedSize != 0)
			warningString += files[i].name + "${JS:gs.getMessage(' is ')}" + getDisplaySize(files[i].size) + "${JS:gs.getMessage('. The maximum file size is ')}" + getDisplaySize(allowedSize) + ".\n";
                if (!isValidFileType(files[i], fileTypes))
                        warningString += files[i].name + "${JS:gs.getMessage(' has a prohibited file extension.')}" + "\n";
        if (warningString != "") {
                alert(warningString);
                clearFileField(field);
                return 0;
        return 1;
function isJEXLExpression(fileName) {
	var phaseOneOpening = fileName.indexOf("$" + "{");
	var phaseTwoOpening = fileName.indexOf("$" + "[");
	if (phaseOneOpening != -1 || phaseTwoOpening != -1) {
		return true;
	return false;
function getDisplaySize(sizeInBytes) {
	var kilobytes = Math.round(sizeInBytes / 1024);
	if (kilobytes < 1)
		kilobytes = 1;
	var reportSize = kilobytes + "K";
	if (kilobytes > 1024)
		reportSize = Math.round(kilobytes / 1024) + "MB";
	return reportSize;
function isValidFileType(file, types) {
	var extensions = types || "";
        if (extensions != "") {
		extensions.toLowerCase();
		extensions = extensions.split(",");
		var periodIndex = file.name.lastIndexOf(".");
        var extension = file.name.substring(periodIndex+1).toLowerCase();
        if (extensions.indexOf(extension) == -1)
			return false;
        return true;
 * Clear a given field's contents.
 * @param field
 * 				the field element.
function clearFileField(field) {
	$(field).clear();
	$(field).parentNode.innerHTML = $(field).parentNode.innerHTML;
 * If the attachments are uploaded, clear any extra attachment input fields so
 * they do not take up as much screen space. Additionally, clear the first field
 * and keep it showing.
function clearAttachmentFields() {
	   if (i == 0)
		   clearFileField(fileFields[0].select('td').first().select('input').first());
	   if (i > 0)
		   fileFields[i].remove();
   setDeleteButton();
// this get called after an attachment is uploaded to update the display
function refreshAttachments(id, fileName, canDelete, createdBy, createdOn, contentType, encryption, iconPath) {
  refreshLiveFeedAttachments(id, fileName, contentType, iconPath);
  var encryptCheck = gel("encrypt_checkbox");
  if (encryptCheck) {
     encryptCheck.checked = false;
     $('sysparm_encryption_context').value = "";
  gel("please_wait").style.display = "none";
  // if we didn't get an id, we could not read the attachment due to business rules so we're done
  if (typeof id == "undefined")
  var noAttachments = gel("no_attachments");
  if (noAttachments.style.display == "block")
     noAttachments.style.display = "none";
  // add the new upload to the display
  var table = gel("attachment_table_body");
  var tr = cel("tr");
  var td = cel("td");
  td.style.whiteSpace = "nowrap";
  td.colspan = "2";
  if (canDelete=="true") {
     var input = cel("input");
     var checkId = "sys_id_" + id;
     input.name = checkId;
     input.id = checkId;
     input.type = "checkbox";
     input.onclick = function() {setRemoveButton(gel(checkId));};
     td.appendChild(input);
     getMessage("Select attachment {0}  for removal", function(msg) {
         var tooltip = new GwtMessage().format(msg, fileName);
         input.setAttribute("aria-label", tooltip);
         input.setAttribute("title", tooltip);
     gel("delete_button_span").style.display = "inline";
     var text = document.createTextNode(" ");
     td.appendChild(text);
     input.type = "hidden";
     input.name = "Name";
     input.value = "false";
  var attachment_input = cel("input");
  attachment_input.className = "attachment_sys_id";
  attachment_input.type = "hidden";
  attachment_input.id = id;
  td.appendChild(attachment_input);
  var anchor = cel("a");
  anchor.style.marginRight = "4px";
  var thisURL = getCurrentPageURL();
  anchor.href = "sys_attachment.do?sys_id=" + id + "&sysparm_this_url=" + thisURL;
  anchor.title = "${JS:gs.getMessage('Attached by')} " + createdBy + " ${JS:gs.getMessage('on')} " + createdOn;
  anchor.tabIndex = "-1";
  var imgSrc = iconPath;
  if (encryption != "") {
     anchor.title += ", ${JS:gs.getMessage('Encrypted')}: " + encryption;
     imgSrc = "images/icons/attachment_encrypted.gifx";
  var img = cel("img");
  img.src = imgSrc;
  img.alt = anchor.title;
  anchor.appendChild(img);
  var text = $(cel('a'));
  getMessage("Download {0}", function(msg) {
	  text.setAttribute("aria-label", new GwtMessage().format(msg, fileName));
  text.href = "sys_attachment.do?sys_id=" + id + "&sysparm_this_url=" + thisURL;
  text.onkeydown = function(event){return allowInPlaceEditModification(text, event);};
  text.style.marginRight = "5px";
  text.style.maxWidth = "75%";
  text.style.display = "inline-block";
  text.style.overflow = "hidden";
  text.style.verticalAlign = "middle";
  if ('innerText' in text)
      text.innerText = fileName;
  else
      text.textContent = fileName;
  text.setAttribute("data-id", id);
  text.inPlaceEdit({
      selectOnStart: true,
      turnClickEditingOff: true,
	  onBeforeEdit: function() {
		  text.lastAriaLabel = text.getAttribute("aria-label");
		  text.removeAttribute("aria-label");
		  text.setAttribute("role", "textbox");
	  onEditCancelled: function() {
		  text.removeAttribute("role");
		  if (text.lastAriaLabel) {
			  text.setAttribute("aria-label", text.lastAriaLabel);
      onAfterEdit: function(newName) {
          var oldName = this.oldValue;
          var ga = new GlideAjax('AttachmentAjax');
          ga.addParam('sysparm_type', 'rename');
          ga.addParam('sysparm_value', id);
          ga.addParam('sysparm_name', newName);
          ga.getXML(function(response){
  	         if (answer !== '0')
                 alert(new GwtMessage().getMessage("Renaming attachment {0} to new name {1} is not allowed", oldName, newName));
             $$('a[data-id="' + id + '"]').each(function(elem){
                 if ('innerText' in elem)
                     elem.innerText = (answer === '0') ? newName : oldName;
                 else
                     elem.textContent = (answer === '0') ? newName : oldName;
             $$('span[data-id="' + id + '"]').each(function(elem){
                 else
		  	 	This routine updates the attachment in the attachment modal AND the same attachment on the parent form
			 getMessage(["Download {0}", "View {0}", "Rename {0}"], function(msg) {
				 var newDownloadText = new GwtMessage().format(msg["Download {0}"], newName);
				 var newViewText = new GwtMessage().format(msg["View {0}"], newName);
				 var newRenameText = new GwtMessage().format(msg["Rename {0}"], newName);
					 elem.setAttribute("aria-label", newDownloadText);
				 $$('.view_' + id).each(function(elem){
					 elem.setAttribute("aria-label", newViewText);
				 $$('.rename_' + id).each(function(elem){
					 elem.setAttribute("aria-label", newRenameText);
  if (contentType == "text/html")
     anchor.target = "_blank";
  td.appendChild(anchor);
  var allowRename = gel('ni.show_rename_link').value;
  if (allowRename == "true") {
	  var renameAttachment = $(cel('a'));
	  renameAttachment.href = "#";
	  renameAttachment.setAttribute("role", "button");
	  getMessage("Rename {0}", function(msg) {
		  renameAttachment.setAttribute("aria-label", new GwtMessage().format(msg, fileName));
	  renameAttachment.className = 'attachment rename_' + id;
	  renameAttachment.onclick = function() {
	    text.beginEdit();
	 renameAttachment.innerHTML = '${JS:gs.getMessage("[rename]")}';
	  td.appendChild(renameAttachment);
  var showView = gel("ni.show_attachment_view").value;
  if (showView == "true") {
      var blank = document.createTextNode(" ");
      tr.appendChild(blank);
      var view = cel("a");
	  view.href = "#";
	  var downloadAttachment = NOW && NOW.g_forceDownloadAttachments;
      var setAriaLabel = function(msg) {
	    view.setAttribute("aria-label", new GwtMessage().format(msg, fileName));
      if (downloadAttachment)
        getMessage("Download {0}", setAriaLabel);
      else
        getMessage("View {0}", setAriaLabel);
      var newText = document.createTextNode(downloadAttachment ? getMessage("[download]") : getMessage("[view]"));
      view.appendChild(newText);
      view.className = "attachment view_" + id;
      if (showPopup == "false")
          view.href = "sys_attachment.do?sys_id=" + id + "&view=true";
      else
          view.onclick = function() {
              tearOffAttachment(id)
      td.appendChild(blank);
      td.appendChild(view);
  var showPopup = gel("ni.show_attachment_popup").value;
  tr.appendChild(td);
  table.appendChild(tr);
	//If a new attachment is added check if attachments are marked for edge encryption before showing the Download all button
	if (!edgeEncryptionEnabledForAttachments && hasAttachments()){
	  gel("download_all_button").style.display = "inline";
  var form_table_id = "";
  if(gel("sys_uniqueValue") || gel("sysparm_attachment_cart_id")){
	  form_table_id = (gel("sys_uniqueValue") || gel("sysparm_attachment_cart_id")).value;
  if(form_table_id && attachmentParentSysId != form_table_id){
	  CustomEvent.fire('record.attachment.uploaded', {
		  sysid: id,
		  hoverText: anchor.title,
		  image: imgSrc,
		  showRename: allowRename,
		  showView: showView,
		  showPopup: showPopup
  }else{
	  addAttachmentNameToForm(id, fileName, anchor.title, imgSrc, allowRename, showView, showPopup);
  if (g_accessibility)
	addInfoAlert(fileName + ' ' + anchor.title);
  $j('#loadFileXml').focus();
function addInfoAlert(message) {
	var alert = '<span class="sr-only" role="alert">' + message + '</span>';
	$j('#alert_container span').remove();
	$j('#alert_container').append(alert);
function refreshLiveFeedAttachments(sys_id, fileName, contentType, iconPath) {
	var p = gel('live_feed_message_images');
	if (!p)
	if (!contentType)
    if (contentType.indexOf('image') != 0 || contentType.indexOf('image/tif') == 0)
		refreshLiveFeedNonImages(p, sys_id, iconPath, fileName);
	else
		refreshLiveFeedImages(p, sys_id, fileName);
	var container = $('live_feed_image_container');
	if (container)
		container.show();
function refreshLiveFeedNonImages(p, sys_id, iconPath, fileName) {
	var a = cel('a');
    a.onclick = function() {tearOffAttachment(sys_id)};
    a.title = fileName;
    a.className = "live_feed_attachment_link";
    var img = cel('img');
    img.src = iconPath;
    img.className = 'live_feed_image_thumbnail';
	img.setAttribute("data-sys_id", sys_id);
    a.appendChild(img);
	var span = cel('span');
    span.setAttribute('data-id', sys_id);
	if ('innerText' in span)
		span.innerText = fileName;
	else
		span.textContet = fileName;
	a.appendChild(span);
    p.appendChild(a);
	p.appendChild(cel('br'));
    setTimeout(this.hideLoading.bind(this), 200);
function refreshLiveFeedImages(p, sys_id, fileName) {
	var imageName = "sys_attachment.do?sys_id=" + sys_id;
	var a = cel('a');
    a.title = fileName;
    img.src = imageName;
    a.appendChild(img);
    p.appendChild(a);
// this get called after attachments are deleted to update the display
function deletedAttachments(sysIds) {
	if (form_table_id && attachmentParentSysId !== form_table_id)
		CustomEvent.fire('record.attachment.deleted', sysIds);
	deleteLiveFeedAttachments(sysIds);
	var modified = $("attachments_modified");
	if (modified)
		modified.value = "true";
   var header_attachment = $('header_attachment');
   gel("deleted_sys_ids").value = ""; // there should be none on the list once we return
   var idArray = sysIds.split(";");
   for (var i=0; i<idArray.length; i++) {
      var id = idArray[i];
      if (form_table_id && attachmentParentSysId === form_table_id)
		changeCount(attachmentParentSysId, 'decrease');
      var e = gel("sys_id_" + id);
      var tr = e.parentNode.parentNode;
      rel(tr);
      e = gel("attachment_" + id);
      if (e)
         rel(e);
   var hasAvailableAttachments = false;
   var hasNotAvailableAttachments = false;
   var i = 0;
   while(i < inputs.length && (!hasAvailableAttachments || !hasNotAvailableAttachments)) {
         if (inputs[i].classList.contains("not_available"))
            hasNotAvailableAttachments = true;
         else
            hasAvailableAttachments = true;
      i++;
   if (!hasAvailableAttachments && !hasNotAvailableAttachments) {
	  gel('delete_button_span').style.display = "none";
	  hideObject($("header_attachment_list_label"));
      if (header_attachment)
    	  header_attachment.style.height = "auto";
      var line = $("header_attachment_line");
      if (line) {
         line.style.visibility = "hidden";
         line.style.display = "none";
   if (!hasAvailableAttachments)
      gel("download_all_button").style.display = "none";
   if(!hasNotAvailableAttachments)
      gel("not_available_files_header").style.display = "none";
   var more_attachments = $('more_attachments');
   if (more_attachments && header_attachment)
   if( (computeAttachmentWidth() - 20) >= (header_attachment.getWidth() - more_attachments.getWidth()))
       more_attachments.style.display = 'block';
   else
       more_attachments.style.display = 'none';
   if (typeof adjustAttachmentsVisibility === 'function')
       adjustAttachmentsVisibility();
function deleteLiveFeedAttachments(sysIds) {
	var p = $('live_feed_message_images');
	if (!p)
	if (!p.visible())
		var imgs = p.select("img.live_feed_image_thumbnail");
		if (imgs.length < 1)
		for (var j=0; j<imgs.length; j++) {
			if (imgs[j].getAttribute("data-sys_id") == idArray[i]) {
				var elem = imgs[j].up("a.live_feed_attachment_link");
				elem.remove();
				if (elem.next() && (elem.next().tagName.toLowerCase() == "br"))
					elem.next().remove();
	if (p.select("img.live_feed_image_thumbnail").length > 0)
	if (container)
		container.hide();
function computeAttachmentWidth() {
	var temp = $('header_attachment_list').select('li');
	var totalWidth = 0;
	for (var i = 0; i < temp.length; i++) {
		totalWidth += temp[i].getWidth();
	return totalWidth;
function closeAttachmentWindow() {
  GlideDialogWindow.get().destroy();
 * Add an input field to the file browser in the dialog.
 * This is called when the "Add Another Attachment" button
 * is clicked.
function addRowToTable() {
   var formRows = $('sys_attachment').select(".attachmentRow");
   var input = "<input type='file' title='${gs.getMessage('Attach')}' " +
		"name='attachFile' onchange='checkAndSetAttachButton(); setDeleteButton(this.value);'" +
		"size=41 multiple=true />";
   var img = "<a href='#' onclick='clearAttachmentField($(this).up().up()); setDeleteButton(this.value);'>" +
		"<img src='images/icons/kb_no.gif'/></a>";
	var row = "<tr class='attachmentRow'><td> "
		+ input + "</td><td align='right'>" + img + "</td></tr>";
	formRows.last().insert({ "after" : row });
 * Download all attachments
function downloadAllAttachments(){
	var downloadUrl = window.location.protocol + '//' + window.location.host + '/download_all_attachments.do?sysparm_sys_id=' + attachmentParentSysId
		+ "&sysparm_this_url=" + getCurrentPageURL();
	window.location = downloadUrl;
function hasAttachments(){
	return document.getElementsByClassName("attachment_sys_id").length > 0;
function renderAttachmentOutputMessages(msgContainerElement) {
	$j('#alert_container .attachment-output-message-container').remove();
	$j('#alert_container').append(msgContainerElement.addClass('attachment-output-message-container compact'));
	if (g_accessibility) {
		$j('#alert_container .btn.btn-icon.close').focus();
