Client script
tushar_ghadage
Hi guys ,
State choice = Closed should be hidden from the form if State = new, for Change Tasks
for that I have written on load client script :
function onLoad() {
    g_form.addOption('state','3');
   if(g_form.getValue('state') == '1')
    g_form.removeOption('state','3');
its working but for other option too showing the choice ' closed 'hidden ..
any correction guys I  need to make??
thankss !!
12 REPLIES 12
Ehab Pilloor
Hi @tushar_ghadage,
Script needs correction to only remove when State is New. Also you would have to make OOB Closed choice inactive for this case as removeOption would remove it for future choices as well so we have to use addOption in script.
Use this script:
function onLoad() {
    // First, always add the 'Closed' option to ensure it's present
    g_form.addOption('state', '3', 'Closed');
    // Then, if state is 'New', remove it
    if (g_form.getValue('state') == '1') {
        g_form.removeOption('state', '3');
Ehab Pilloor
its hiding it for other option as well
Hi @tushar_ghadage, did you try saving the record and check?
It will not show on new record, remember its onLoad script, save and try it.
reshmakore57046
Hello @tushar_ghadage ,
To achieve this efficiently, you can use a onLoad client script.
function onLoad() {
var closedValue = '3'; // Value for 'Closed'
var closedLabel = 'Closed'; // Update if label is different
// Reusable function to update the visibility of 'Closed' option
function updateClosedOption(stateValue) {
if (stateValue === '1') { // '1' = New
g_form.removeOption('state', closedValue);
if (!g_form.getOption('state', closedValue)) {
g_form.addOption('state', closedValue, closedLabel);
// Run once on form load
updateClosedOption(g_form.getValue('state'));
// Watch for changes to the state field
g_form.watch('state', function(newValue) {
updateClosedOption(newValue);
Reshma Kore.
