Client script
tushar_ghadage
Hi guys ,
State choice = Closed should be hidden from the form if State = new, for Change Tasks
for that I have written on load client script :
function onLoad() {
    g_form.addOption('state','3');
   if(g_form.getValue('state') == '1')
    g_form.removeOption('state','3');
its working but for other option too showing the choice ' closed 'hidden ..
any correction guys I  need to make??
thankss !!
12 REPLIES 12
Ankur Bawiskar
@tushar_ghadage
script from @Chaitanya ILCR should work
what debugging did you do?
as you can see in the SS
option is getting removed but its not getting added when open choice is unselected :
below is the script :
function onLoad() {
    // Then, if state is 'New', remove it
    g_form.addInfoMessage('checking one');
    if (g_form.getValue('state') === '1') {
        g_form.addInfoMessage('checking 2');
        g_form.removeOption('state', '3');
    else
        g_form.addInfoMessage('checking 3');
        g_form.addOption('state', '3', 'Closed');
Hi @tushar_ghadage ,
for whatever your trying to do you require an onchange client script
update you client script as below
    if (isLoading) {
        if (newValue == '1')
    else {
        g_form.addOption('state', '3', 'Closed',3)
but the approach is wrong
with this the purpose of removing closed state on open change is of no use as users can select anyother value to make closed to appear on a open change tasks and select the close directly where the state of change task is still open
they have to save the form first with their option
you have to go with the onload client script here in this scenario(you can refer my first response for that)
but this is what you want update your client script as mentioned
Chaitanya
