Client side confirm before Business Rule updates
Daryll Conway
Giga Guru
I have a function in a business rule that checks submission times of a change request against the first change task start date and the current CAB times.
I have the BR working fine but I've been asked to add a user confirmation to this process which will reject the submission is they choose and as this is all handled in a business rule I'm struggling to do this.
First of all thought I'll just add a boolean return using g_scratchpad that would trigger the confirmation in a client script but by the time I've got to the client script the business rule has already made the changes and has been submitted.
Can anyone think of a way to stop submission of a business rule (although I need to run to a point to decide if the client confirmation should be shown),
then from the user response submit or cancel?
Here is my business rule...
// Only check late if one of the given Business Entities and type is Normal or Emergency
var be = String(current.u_affected_business_entities);
var beList = [];
if(be.toLowerCase().indexOf(',') > -1){
      beList = be.split(',');
var stop = false;
if(beList.length>0){
      for(i=0;i<beList.length;i++){
              if(beList[i] == '5e58bb82a069d10040a915194b1407b8' || beList[i] == 'd89ba3e90f62350006ecd7b003050ed8'){
                      stop = true;
else{
      if(be == '5e58bb82a069d10040a915194b1407b8' || be == 'd89ba3e90f62350006ecd7b003050ed8'){
              stop = true;
// UK CAB - Thursday @ 15:00 PM BST & Tuesday @ 9:00 BST
// Variables Start
var sdt;
if(current.work_start != ''){
      sdt = fixDateFormat(current.work_start.getDisplayValue()); //First Task Date/Time field
else{
      sdt = fixDateFormat(previous.work_start.getDisplayValue()); //First Task Date/Time field
var nowTimeDate = gs.nowDateTime();
var nowConverted = fixDateFormat(nowTimeDate);
var nowTime = String(nowConverted.split(' ')[1]);
var iLocalHours = nowTime.split(':')[0];
var nowTimeHour = parseInt(iLocalHours);
var tskTime = sdt.split(' ')[1];
var tskTimeHour = parseInt(tskTime.split(':')[0]);
var now = new GlideDateTime(String(nowConverted));
var tsk = new GlideDateTime(String(sdt));
var dayTsk = tsk.getDayOfWeek();
var daySub = now.getDayOfWeek();
var dateDiff = parseInt(gs.dateDiff(nowConverted, sdt, true));
var late = false;
g_scratchpad.emergency = false;
g_scratchpad.late = false;
// Variables End
function checkLate() {
      if((current.type == 'Emergency' || current.type == 'Normal') && !stop)
              // Check if we have a submission date if not add one
              if(current.u_submitted_date == ''){
                      current.u_submitted_date = nowTimeDate;
              // Kick off the function "getDates()" below...
              getDates();
function getDates(){
      if(current.work_start == '' && previous.work_start == ''){
              // Do nothing we have no dates to work with
      else{
              if(dateDiff < 518400 /* 6 Days */ && dateDiff > 7200 /* 2 Hours - Emergency if less than this*/){
                      resultShow();
              if(dateDiff < 7200 /* 2 Hours - Emergency if less than this*/){
                              g_scratchpad.late = true;
                              g_scratchpad.emergency = true;
function resultShow(){
      // Submit and Task date both between Tuesday 9am & Thursday 2pm CABs
      if(((daySub > 2 || daySub < 4 ) || (daySub == 2 && nowTimeHour > 9) || (daySub == 4 && nowTimeHour < 14)) && (dayTsk > 2 || dayTsk < 4 || (dayTsk == 2 && tskTimeHour > 9) || (dayTsk == 4 && tskTimeHour < 14))) {
              late = true;
      // Submit and Task date both between Thursday 2pm & Tuesday 9am CABs
      if(((daySub > 4 || daySub <=1 )|| (daySub == 2 && nowTimeHour < 9) || (daySub == 4 && nowTimeHour > 14)) && (dayTsk >= 4 || dayTsk <=1 || (dayTsk == 2 && tskTimeHour < 9) || (dayTsk == 4 && tskTimeHour == 14))){
              late = true;
      if(late) {
      else{
// Rearrange date/time format
// FROM : dd-MMM-yyyy hh:mm:ss
// TO : yyyy-MM-dd hh:mm:ss
function fixDateFormat(date){
      if (date !== null){
              var time = date.split(' ')[1];
              var dateWhole = date.split(' ')[0];
              var year = dateWhole.split('-')[2];
              var mon = dateWhole.split('-')[1];
              var day = dateWhole.split('-')[0];
              var rmonth = '';
              if (mon.toLowerCase() == 'jan')
                      rmonth = '01';
              if (mon.toLowerCase() == 'feb')
                      rmonth = '02';
              if (mon.toLowerCase() == 'mar')
                      rmonth = '03';
              if (mon.toLowerCase() == 'apr')
                      rmonth = '04';
              if (mon.toLowerCase() == 'may')
                      rmonth = '05';
              if (mon.toLowerCase() == 'jun')
                      rmonth = '06';
              if (mon.toLowerCase() == 'jul')
                      rmonth = '07';
              if (mon.toLowerCase() == 'aug')
                      rmonth = '08';
              if (mon.toLowerCase() == 'sep')
                      rmonth = '09';
              if (mon.toLowerCase() == 'oct')
                      rmonth = '10';
              if (mon.toLowerCase() == 'nov')
                      rmonth = '11';
              if (mon.toLowerCase() == 'dec')
                      rmonth = '12';
              return year+'-'+rmonth+'-'+day + ' ' + time;
      else
              return '0';
checkLate();
Daryll Conway
Giga Guru
Just to tie this one up here is my final working scripts...
Client Script (onSubmit)
function onSubmit() {
      if(g_form.getActionName() == 'changeSubmit'){
              var late = false,
              emergency = false,
              subTime,
              Ready2Submit = false,
              sub,
              ws = String(g_form.getValue('work_start')),
              be = String(g_form.getValue('u_affected_business_entities')),
              type = String(g_form.getValue('type'));
              var ga = new GlideAjax('CHGLateSub');
              ga.addParam('sysparm_name','late');
              ga.addParam('sysparm_work_start', ws);
              ga.addParam('sysparm_be', be);
              ga.addParam('sysparm_type', type);
              ga.getXMLWait();
              var answer = ga.getAnswer();
              late = answer.split(',')[0];
              emergency = answer.split(',')[1];
              subTime = answer.split(',')[2];
              //alert('late = ' + late + ' : Emergency = ' + emergency + ' : Submission Time = ' + subTime);
              if(late == 'true' || emergency == 'true'){
                      if(confirm('This Change Request has been submitted late, and will therefore miss Change Advisory Board (CAB) review. Normal, business-impacting changes should be submitted for review at the CAB meeting. Do you still wish to submit for this date/time?')){
                              g_form.setValue('u_submitted_late', 'true');
                              g_form.setValue('u_submitted_date', subTime);
                              if(emergency == true){
                                      g_form.setValue('type', 'Emergency');
                              return true;
                      else{
                              //g_form.setValue('u_submitted_late', 'false');
                              return false;
Script Include...
var CHGLateSub = Class.create();
CHGLateSub.prototype = Object.extendsObject(AbstractAjaxProcessor,{
      late: function() {
              gs.log('CHGLateSub started', 'DC Log');
              var be = String(this.getParameter("sysparm_be"));
              var work_start = this.getParameter("sysparm_work_start");
              var type = this.getParameter("sysparm_type");
              var beList = [];
              var stop = false;
                                      stop = true;
              else{
                              stop = true;
              // Variables Start
              var sdt;
              if(work_start != ''){
                      sdt = fixDateFormat(work_start); //First Task Date/Time field
              var late = false;
              var emergency = false;
              // Variables End
                      if((type == 'Emergency' || type == 'Normal') && !stop)
                              getDates();
                      if(work_start == ''){
                              // Do nothing we have no date to work with
                      else{
                                      resultShow();
                                      late = true;
                                      emergency = true;
                      if((daySub == 2 && nowTimeHour > 9) || (daySub == 3) || (daySub == 4 && nowTimeHour < 14)){
                              if((dayTsk == 2 && tskTimeHour > 9) || (dayTsk == 3) || (dayTsk == 4 && tskTimeHour < 14)){
                                      gs.log('Between Tuesday 9am & Thursday 2pm CABS : day of submission = ' + daySub + ' Hour = ' + nowTimeHour + ' : day of first task = ' + dayTsk + ' Hour = ' + tskTimeHour, 'DC Log');
                                      late = true;
                      if((daySub == 4 && nowTimeHour > 14) || (daySub == 5 || daySub == 6 || daySub == 7) || (daySub < 2 || (daySub == 2 && nowTimeHour < 9))){
                              if((dayTsk == 4 && tskTimeHour > 14) || (dayTsk == 5 || dayTsk == 6 || dayTsk == 7) || (dayTsk < 2 || (dayTsk == 2 && tskTimeHour < 9))){
                                      gs.log('Between Thursday 2pm & Tuesday 9am CABS : day of submission = ' + daySub + ' Hour = ' + nowTimeHour + ' : day of first task = ' + dayTsk + ' Hour = ' + tskTimeHour, 'DC Log');
                                      late = true;
                      if (date !== null){
                              var rmonth = '';
                                      rmonth = '01';
                                      rmonth = '02';
                                      rmonth = '03';
                                      rmonth = '04';
                                      rmonth = '05';
                                      rmonth = '06';
                                      rmonth = '07';
                                      rmonth = '08';
                                      rmonth = '09';
                                      rmonth = '10';
                                      rmonth = '11';
                                      rmonth = '12';
                      else
                              return '0';
              checkLate();
              return late + ',' + emergency + ',' + nowTimeDate;
      type: 'CHGLateSub'
Daryll Conway
Giga Guru
              var late = false,
              emergency = false,
              subTime,
              sub,
              ga.getXMLWait();
                              return true;
                      else{
                              return false;
Script Include...
      late: function() {
              var beList = [];
              var stop = false;
                                      stop = true;
              else{
                              stop = true;
              // Variables Start
              var sdt;
              var late = false;
              // Variables End
                              getDates();
                      else{
                                      resultShow();
                                      late = true;
                                      emergency = true;
                                      late = true;
                                      late = true;
                      if (date !== null){
                              var rmonth = '';
                                      rmonth = '01';
                                      rmonth = '02';
                                      rmonth = '03';
                                      rmonth = '04';
                                      rmonth = '05';
                                      rmonth = '06';
                                      rmonth = '07';
                                      rmonth = '08';
                                      rmonth = '09';
                                      rmonth = '10';
                                      rmonth = '11';
                                      rmonth = '12';
                      else
                              return '0';
              checkLate();
      type: 'CHGLateSub'
divvi_vamsi
Mega Expert
I have a similar issue, but confirmation should occur only after script include returns soemthing, else it shouldn't. Is there a way to achieve this?
