CMDB groups and changes
Eric M
Giga Expert
In the Istanbul and jakatra release came the concept of CMDB groups. anyone using them with change ? and how are you using them?
Best,
Eric
johnfw
Kilo Expert
Hi Eric, wish I could help, but have the same question.
In the CI field in CHG, I want users to be able to select a group, and then all CIs within that group to populate the 'affected CIs' related list.
We tried overriding the reference qualifier with "sys_class_name=cmdb_ci_server^ORsys_class_name=cmdb_group" but this didn't work.
If you have had any luck, please share
John
34 REPLIES 34
Do you still have this update set?  The download on ServiceNowGuru is no longer available.  webprincess98@gmail.com
Here you go!
Thank you!
Paul Coste2
Giga Expert
@Michael - You are referring to the CI Group, not the CMDB Group.   They are different.   CMDB Group is a new feature in Istanbul.   The ServiceNowGuru script you are using uses the cmdb_ci_group class, which is actually a CI.   The CMDB Group class doesn't work like this, because it cannot be used as a CI itself.
Appears the tables are different, but looking at it, seems like similar functionality to legacy groups. Difference is this looks smarter. You can build a query and looks like it will auto add to the group versus manually having to update all the time when new devices are added.
