CMDB Integration between two SN instances
Geeky
I have a requirement to integrate between two servicenow instances. One instance is having a CMDB data and other one is empty. So there will be two things here to complete;
1) One time sync of CMDB data:   We may need to bring in the CMDB data from One instance to Other one only for the first time. I thought to do it by XML/Excel/transform maps but data is huge.
2) Continues sync of CMDB data: Data should be continuously synced from one instance to other instance.
Can we expose schema of one servicenow instance to other servicenow instance so that data can be syched automatically?
Please let me know if you have any idea about it.
Srini
Vinayak Nikam
Hi Greeky,
Have you done this. if yes please let me know the steps how you achieve this.
Thanks in Advance.
