CMDB Remediation Rules
klautrup
Kilo Expert
I have configured a CMDB orphan rule in the Health Dashboard identifying orphan MS SQL Database CIs in cmdb_ci_db_mssql_database if they do not have the CONTAINED BY relation to a MS SQL Instance CI in Fcmdb_ci_db_mssql_instance.
I now want to configure a CMDB Remediation Rule where it seems I have to create a workflow:
If I then click the magnifying glass next to 'Workflow' I get a pop-up allowing me to create a workflow:find_real_file.png
Submitting that workflow brings me to the workflow canvas:
Now if I Publish that workflow and return to the create CMDB Remediation Rule form it has put the new workflow in the 'Workflow' field:find_real_file.png
But if I try to Submit that it is blanked out:
And hitting the magnifying glass again doesn't show the published workflow (if I open the workflow editor directly I see the workflow as published).
The documentation how to create a CMDB Remediation Rule seems very sparse. Anybody having successfully created such a rule?
Christian Chamb
The flow should be created on the same table as the remediation task, for instance, if u are creating a remediation on stale cis, then the workflow should also refer to the stale task table
