Comparing List Collector Values with another variable, if it matches show alert
Nasir1
Sorry it might be a noob question but I have catalog item that has a list collector (employee_current_roles) which auto-populates user's roles with all the roles user is member of, I have another variable (role) on the form that is reference field and users can pick up any roles and log the request.
What I want to do is If any of the roles in list collector matches the value in referenced field I want a pop up to say User is already member of the role but I am not sure if what I am doing is correct, please help.
    var urole = g_form.getValue('role');
    var gr = g_form.getValue('employee_current_roles'); //  getting the List Collector Variable value
    var ar = gr.split(','); // split the list collector by comma
    for (var i = 0; i < ar.length; i++);
    if (ar.indexOf(urole) == -1) //if field values are the same then send alert
        alert('User is already Member of the Selected role');
        g_form.clearValue('role');
That's strange issue,
Can you try adding below alert to see what values those variables are storing:
	if (gr.indexOf(urole) > -1) //if field values are the same then send alert
                alert("gr value :"+gr+" urole : "+urole);
with new alert you might understand the exact issue else show me the alert data you are getting so that I can help you further.
Let me know if you have any further queries.
Please mark this as Correct or Helpful if it helps.
Thanks and Regards,
Abhijit
Community Rising Star 2022
By marking my response as correct or helpful, you contribute to helping future readers with similar issues.
Abhijit
ServiceNow MVP
32 REPLIES 32
Let me explain
This is the list collector values
and now these are the roles in the drop down
As you can see the drop down has two choices, the first choice is in list collector but the second is not, now the problem is when even select the value which is not in list collector it still pops up.
Does that make sense? If not please let me know and I will upload a video showing what exactly its doing.
Thank You.
Thanks and Regards,
Abhijit
Abhijit
ServiceNow MVP
I am now feeling embarrassed, I am sorry it still wont display any alerts.
Muhammad Khan
Hi Nasir,
I believe that this onChange Catalog Client Script is on role field. Can you try the following script.
    if (ar.indexOf(newValue) >= 0) //if field values are the same then send alert
You can also try with a javascript array method which is array.includes.
Hopefully, this will resolve your query.
Hi Muhammad,
Thank you, that's correct I have onChange Catalog Client script on role field, I tried what you mentioned and unfortunately it does not pop up at all, even tried
if (ar.indexOf(newValue) > -1)
This won't work too :(. I can do a look up of both the fields in flow designer and stop the flow from executing to next approval stage, but honestly its annoying and I know users will call back asking for the same thing to show reminder on the portal.
