Comparing values in two tables
Prashant Kumar6
Giga Guru
Hello Experts,
I have two tables :
1: "sys_atf_test" where I have field called "Name" string type.
2: "tm_test_case" where I have field called "ATF Test Name" string type.
I want to check if there is any common values in both table fields through script ,Also I want to print the value which is common in both table fields. Any help ?Thanks.
@Prashant Kumar6 Try with following.
var glideATFTest = new GlideRecord('sys_atf_test');
glideATFTest.query();
while(glideATFTest.next){
var glideTestCase = new GlideRecord('tm_test_case');
glideTestCase.addEncodedQuery('u_atf_test_nameLIKE'+glideATFTest.getDisplayValue('name'));
glideTestCase.query();
if(glideTestCase.next()){
gs.info('Found a duplicate name '+glideTestCase.getValue('u_atf_test_name'));
Also, in order to find the correct query, I recommend you to do a manual search on u_atf_test_name field on list view of sys_atf_test table, copy the encoded query and use the same here in this script.
Danish Bhairag2
Tera Sage
Hi @Prashant Kumar6 ,
You can try with below script
(function() {
    // Query records from sys_atf_test table
    var sysATFTestGr = new GlideRecord('sys_atf_test');
    sysATFTestGr.query();
    // Query records from tm_test_case table
    var tmTestCaseGr = new GlideRecord('tm_test_case');
    tmTestCaseGr.query();
    // Array to store common values
    var commonValues = [];
    // Iterate through sys_atf_test records
    while (sysATFTestGr.next()) {
        var sysATFTestName = sysATFTestGr.name.toString().toLowerCase();
        // Iterate through tm_test_case records and compare with sys_atf_test names
        while (tmTestCaseGr.next()) {
            var tmTestCaseName = tmTestCaseGr.getValue('atf_test_name').toString().toLowerCase();
            // Check for common names (case-insensitive)
            if (sysATFTestName === tmTestCaseName) {
                // Add the common value to the array
                commonValues.push(sysATFTestName);
                break; // Exit the inner loop after finding a match
        // Reset tm_test_case GlideRecord for the next iteration
    // Print common values
    gs.info('Common values in "Name" field of sys_atf_test and "ATF Test Name" field of tm_test_case:');
    commonValues.forEach(function(value) {
      gs.info(value);
Mark my answer helpful & accepted if it helps you resolve your query.
Danish
