Conditional Reference Qualifiers
JonnyFoster
Afternoon everyone.
Looking for a bit of help - I'm creating a new catalog item. We have a mandate that will only let our 'regular users' (i.e., not IT staff) managers have to request access for their staff for certain items, which I've achieved by putting on a reference qualifier on the requested_for variable (manager is (dynamic) me, or manager_manager is (dynamic) me) .
I need to be able to override this for my Service Desk team to be able to raise requests for anyone in the Business.
Is it possible to make the reference qualifier conditional at all?
Many thanks!
@JonnyFoster
you can use advanced ref qualifier as this
-> if logged in user doesn't have itil role then it applies the reference qualifier and restricts the users
-> if logged in user has itil role then no query it means it will show all active users
javascript: var query = '';
if (!gs.hasRole('itil'))
    query = 'manager=' + gs.getUserID() + '^ORmanager.manager=' + gs.getUserID();
query;
9 REPLIES 9
@JonnyFoster
there is a typo in your ref qualifier, please correct that and it should work
colon : is replaced with :
This is known issue when we post in community and it converts that character automatically
I thought it looked odd!!
Ankur, that has worked a treat. Thank you so much!!
Anand__99
Hi @JonnyFoster ,
Yes, you can add multiple conditions to the reference qualifier. Use Advanced reference qualifier to build your conditions.
A sample code:
javascript:
var query;
var groupName = current.variables.<variable_name>;
var membershipUtils = new global.<your_script_include>();
if (current.variables.<variable_name> == "<condition>") {
query = 'active=true^sys_idNOT IN' + membershipUtils.<method_name>(<parameters>);
} else if (current.variables.<variable_name> == "<Condition>") {
query = 'active=true^sys_idIN' + membershipUtils.<method_name>(<parameters>);
query = 'active=true';
query;.
Refer these links:
Reference qualifiers
Reference Qualifiers in ServiceNow - ServiceNow Community
Anand
MaxMixali
Hi you can try this script:
Navigate to your catalog item, edit the requested_for variable,
and in the reference qualifier field enter:
javascript&colon;(function() {
if (gs.hasRole('itil')) {
return 'active=true';
var managerId = gs.getUserID();
var userList = managerId;
gr.addQuery('manager', managerId);
while (gr.next()) {
userList += ',' + gr.sys_id;
var gr2 = new GlideRecord('sys_user');
gr2.addQuery('manager.manager', managerId);
gr2.query();
while (gr2.next()) {
userList += ',' + gr2.sys_id;
return 'active=true^sys_idIN' + userList;
No dice on this one, Max, I'm afraid. Nothing changed, apart from all users were available whether a role is applied or not.
Thanks for your help, though...
