Confirmation Dialog Box using UI Page, OK Button will not work
Gary Martin
Mega Contributor
When cancelling a change, I am using a confirmation dialog box that pops up to enter reason and select OK.  When I enter the reason, select OK, nothing happens.  I xml'd the ui page and the Cancel change ui action from my personnel development instance because it works there.  I must be forgetting another piece like a client script or something?  Below is the information.  I just need to get the OK button to do something when I click it.
UI Page: Change_confirm_cancel
HTML:
<g:dialog_notes_ok_cancel
dialog_id="change_confirm_cancel"
textarea_id="change_confirm_reason_text"
textarea_label="${gs.getMessage('Reason')}"
textarea_label_title="${gs.getMessage('A reason is required to cancel this change')}"
textarea_name="change_confirm_reason_text"
textarea_onkeyup="enableButton()"
textarea_onchange="enableButton()"
textarea_style="height:auto; width: 100%; resize: vertical;"
textarea_title="${gs.getMessage('Enter the reason here')}"
ok=""
ok_action="cancelChangeRequest"
ok_id="change_confirm_ok_btn"
ok_title="${gs.getMessage('Cancel change request')}"
ok_type="button"
ok_style_class="btn btn-primary disabled"
cancel_title="${gs.getMessage('Close the dialog')}"
</j:jelly>
UI Page Client script:
function cancelChangeRequest() {
var textArea = $("change_confirm_reason_text");
if (textArea)
moveToCancel(textArea.value.trim());
(function() {
$("change_confirm_reason_text").focus();
Cancel Change UI Action:
UI Action Script:
var changeConfirmCancelDialog;
function loadConfirmDialog() {
var dialogClass = window.GlideModal ? GlideModal : GlideDialogWindow;
changeConfirmCancelDialog = new dialogClass("change_confirm_cancel", false, 648, 250);
changeConfirmCancelDialog.setTitle(new GwtMessage().getMessage("Cancel Change Request"));
changeConfirmCancelDialog.render();
function moveToCancel(notes) {
var ga = new GlideAjax("ChangeRequestStateHandlerAjax");
ga.addParam("sysparm_name", "getStateValue");
ga.addParam("sysparm_state_name", "canceled");
ga.getXMLAnswer(function(stateValue) {
g_form.setValue("state", stateValue);
g_form.setValue("work_notes", notes);
changeConfirmCancelDialog.destroy();
gsftSubmit(null, g_form.getFormElement(), "state_model_move_to_canceled");
if (typeof window == 'undefined')
setRedirect();
function setRedirect() {
current.update();
Sheryl Lyke2
Thanks, Gary. I think one of my issues was I was using the gel function which I read sometimes doesn't work in a ui page. I replaced with getElementById. I'm using a reference field and not a text field so that may be different. Thanks for the response!
Naveen V1
Hi @Gary Martin. I have a requirement to add dropdown field in popup instead of multiline text within <g:dialog_notes_ok_cancel>. Can you tell how can we modify the script?
