convert array to a pipe delimited string
nick135
Hello everyone,
I have a list collector on a catalog item. When the item is submitted the Values of the field on the RITM/SCTASK appear as "a, b, c". I've been asked to convert this format to "a | b | c". so basically the ask here is to remove the comma and insert a pipe. the script I have so far looks a bit like this
var arr = g_form.getValue('compliance');
var list;
console.log(arr);
for(var i = 0; i <= arr.length; i++) {
list += arr[i] + " | ";
console.log(list);
g_form.setValue('comliance_test', list);
the problem I'm having is that the list comes back up undefined, and I also end up with an extra pipe added to the end of the string. any ideas?
vkachineni
var list_comma = "abc,def,ghi";
var arr = list_comma.split(",");
var list_pipe = arr.join('|'); //join back with pipe
gs.print(list_comma);
gs.print(list_pipe);
*** Script: abc,def,ghi
*** Script: abc|def|ghi
Tested example :
Output :
vkachineni
This worked, thanks a bunch!
