Copy fields from "Problem Ticket" to "Problem Task Ticket"
kam_steven_
I have created a client script to copy fields from "Problem Ticket" to "Problem Task Ticket", it didn't work. Can someone guide me through?
Table=Problem
Type=onLoad
function onLoad() {
if(g_form.isNewRecord() && g_form.getValue('parent') != ''){
var prb = g_form.getReference('parent', setFields);
function setFields(prb){
g_form.setValue('assignment_group',prb.assignment_group);
g_form.setValue('priority',prb.priority);
Thanks.
Steven
And then do javascript:parent.priority for an override on the priority.
29 REPLIES 29
Pradeep Sharma
Hi Kam,
This will not work. You have to query the problem_task table to update the record. However I would recommend you to create a business rule(after insert update checkbox to true) on problem table.
Here is the script. Please modify it as per your req.
updateRec();
function updateRec()
  var probTask = new GlideRecord('problem_task');
  probTask.addQuery('problem', current.sys_id); //query all problem tasks
  probTask.query();
  while(probTask.next())
  probTask.assignment_group = current.assignment_group;
  probTask.priority = current.priority;
  probTask.update();
It's not working ... Am I doing wrong?
Mike Allen
You can do an display business rule that says:
current.assignment_group = current.parent.assignment_group;
current.priority = current.parent.priority;
It's not working. Am I making mistakes?
