Copy Work Notes from Problem to Incident and Vice Versa
Chintha Murali
Mega Expert
I have a requirement to copy worknotes from problem to incident and vice versa.
Please help me with this.
Thank you.
Hi @Chintha Murali krishna
Please find the updated Business Rules below (these will surely work 😉)
Remark: Make sure both the Business Rules are on Insert and Update + When = Before
Incident:
    var identifier = '[Comment Sync]';
    if (current.work_notes.indexOf(identifier) < 0) {
        var getProblems = current.problem_id.getRefRecord();
        getProblems.work_notes = identifier + '\n' + current.work_notes;
        getProblems.update();
})(current, previous);
Problem:
        var getIncidents = new GlideRecord('incident');
		getIncidents.addQuery('problem_id', current.getValue('sys_id'));
		getIncidents.query();
		while(getIncidents.next()) {
			getIncidents.work_notes = identifier + '\n' + current.work_notes;
			getIncidents.update();
Please mark my answer as correct if this solves your issues!
If it helped you in any way then please mark helpful!
Thanks and regards,
Kartik
tested your code and it works fine, IF the incident does not have any other related records.
When incident has 'change reguest' as related record, every time comment is copied, the script creates empty change ticket and the only thing on the empty record is the worknote that was copied to incident from problem
RonankiChandu
It's working Thanks
Hi@kartiksethi can you suggest any other approach instead of keeping Identifier, In my use case it  was just a sync should happen from Incident to Problem and Vice versa!
Thanks & Regards,
Eswar Chappa
