Copying string field value into reference field
Hi There,
Greetings!!!
I am copying records from Table A to Table B on condition If field of Table C is set to "Selected"
I have a requirement to copy string value "Number" which is on Table A to reference field "CWD Number" on Table B
I have written a business rule, it's copying the task from Table A to Table B but not copying the Number to CWD Number:
Business Rule:
Script:
    var gr = new GlideRecord('x_infte_diversity_course_week_detail');
    gr.addQuery('course_number.sys_id', '535e228e478bfd1088119ac5536d43b7');
    while (gr.next()) {
        var gr1 = new GlideRecord('x_infte_diversity_course_task_for_registered_user');
        gr1.initialize();
        var str_value = gr.number;
        //gs.info("The Number is :" +str_value);
        gr1.cwd_number.setDisplayValue(str_value);
        //gs.info("Number is :"+gr.number);
        //gr1.cwd_number = gr.number;
        //gr1.setDisplayValue("cwd_number", number);
        gr1.week_number = gr.week_number;
        gr1.description = gr.week_description;
        gr1.short_description = gr.agenda;
        gr1.insert();
})(current, previous);
Note: It's not copying some of the fields.
19 REPLIES 19
Please try with the below code :
gr1.cwd_number.setDisplayValue(gr.number);
Thanks!
Hello @Community Alums,
Thanks!
Prathamesh G
Continued from my previous response, You can use below syntax:
gr1.cwd_number.setDisplayValue('number'); //Use the backend value of the variable
or
gr1.cwd_number.setDisplayValue(current.number);
If the above answer resolve your issue, Please mark the solution as 'Accepted Solution' and also mark it as 'Helpful'.
Thank You!
Prathamesh.
No luck @Prathamesh G
vipinmathew
Mega Guru
Hi @Community Alums ,
Could you please give me insight for below queries,
  • You have created After BR on which table?
  • course_number field in x_infte_diversity_course_week_detail tableis referencing to which table ?
  • cwd_number field in x_infte_diversity_course_task_for_registered_user table is referencing to which table ?
Vipin Mathew
