Create a problem Record when incident ticket is created in Business Rules
Sai Mithra Siri
In Business rules
Hi @Sai Mithra Siripuram ,
This is done with a UI action called "Create Problem". It is available from the form menu (or right-click on the form header.) You can find the definition for this UI action in your instance here:
https://YOURINSTANCE.service-now.com/nav_to.do?uri=sys_ui_action.do?sys_id=2f43c471c0a8006400a07440e...
If you are looking at a BR, then below script in before BR on incident table:
- Configuration item
- Priority
- Assignment group
- Short Description
- Description
        var newPRB = new GlideRecord('problem');
        newPRB.cmdb_ci = current.cmdb_ci;
        newPRB.location = current.location;
        newPRB.short_description = 'PRB raised' + current.number + ' - Auto Generated';
        newPRB.description = 'PRB raised  ' + current.number + '\nIncident description: ' + current.description;
        newPRB.assignment_group = current.assignment_group;
        newPRB.insert();
current.problem_id = newPRB.sys_id;
})(current, previous);
Mark my answer correct & Helpful, if Applicable.
Sandeep
- Priority
- Assignment group
- Short Description
- Description
        newPRB.insert();
Sandeep
Kindly mark the applicable answer as Correct & Helpful both such that others can get help.
Sandeep
Snehangshu Sark
Giga Guru
Hi Sai,
Please use the BR and do the field mapping before you apply it. In the BR, set the Table as "Incident".
In the field mapping, prb contains the problem ticket that is going to be created and current is the incident table.
    var prb = new GlideRecord('problem');
	prb.initialize();
    prb.<fieldName> = current.<fieldName>;  // do the field mapping
    prb.insert();
Snehangshu Sarkar
Please mark an appropriate response as correct if my answer replied to your question.
pratiksha5
user after business rule on incident table, mark it after insert.
var gr = new GlideRecord("problem");
gr.initialize();
gr.short_description = current.short_description;
gr.first_reported_by_task = current.sys_id;
gr.assingment_group = current.assingment_group;
gr.description = "this is a problem record created by an incident";
gr.cmdb_ci = current.cmdb_ci;
gr.insert();
