02-13-2018 08:29 AM
I need to create an additional work notes field, that performs in the same way that the existing work notes field does but called something different. I am not sure what type of field the work notes field is or how I would add an additional one that behaves the same, any help welcome
Kind regards
Clive
Incident Management
02-14-2018 05:09 AM
Some fields don't let you see it I suppose. My apologies.
Anyways, you'd need to navigate to Dictionary > and search for Work Notes, which is essentially part of the Task table.
So you'd want to make a custom field on your new table that replicates this to an extent and type Journal Field which should come with it's own 'Post' button.
See: Add a work notes journal field (with post button) to form
02-14-2018 07:00 AM
Great job!
Glad I could help!
