Create each task for every entry on Multi Row Variable Set (MRVS)
Shruti Navalgu1
I am trying to create each task for every entry on the multi-row variable set. I am using flow designer to achieve but it doesn't work, please let me know if there is any other way to get through this
asifnoor
Hello Shruti,
You can write after Br on sc_req_item and can create catalog tasks. you can try like this
After insert on sc_req_item
condition: item is <your_cat_item>
Script
var mrvs = current.variables.your_mrvs_name;
var rowCount = mrvs.getRowCount();
for (var i = 0; i < rowCount; i++) {
  //if you wnat to read data from mrvs and assign to task then
  var row = mrvs.getRow(i);
  var sc_task = new GlideRecord("sc_task");
  sc_task.initialize();
  sc_task.short_description = row.your_variable;
  sc_task.insert();
Mark the comment as a correct answer and also helpful if it helps to solve the problem.
18 REPLIES 18
Shruti Navalgu1
Hi Asif,
Thank you for writing back 🙂
I tried the above script, the insertion isn't happening as the details of the MRVS is printing in array format. Please find the below-
So i did parsing with the below script -
var mrvs = current.variables.for_bulk_request;
gs.log('mrvs: ' + mrvs);
gs.log('RowCount: ' + rowCount);
var fromCount = 0;
var i;
var j;
var row;
var parser = new global.JSONParser();
var parsed = parser.parse(mrvs);
gs.log('Parsed: ' + parsed);
gs.log('Parsed123: ' + parsed.length);
var pLength = parsed.length;
for (i = 0; i < pLength; i++) {
var peripheralType = parsed.mrvs[i].u_please_select_type_of_computer_peripherals_mv;
var compPeripheral = parsed.mrvs[i].u_please_select_computer_peripherals_mv.toString();
var abNumber = parsed.mrvs[i].ab_number_mv;
var location = parsed.mrvs[i].location_mv.toString();
var costCentre = parsed.mrvs[i].cost_centre_mv.toString();
var brid = parsed.mrvs[i].brid_mv;
var name = parsed.mrvs[i].name_mv.toString();
sc_task.short_description = 'Task for Hardware Team to coordinate device provisioning to user';
sc_task.u_please_select_type_of_computer_peripherals_mv = peripheralType;
sc_task.u_please_select_computer_peripherals_mv = compPeripheral;
sc_task.ab_number_mv = abNumber;
sc_task.location_mv = location;
sc_task.cost_centre_mv = costCentre;
sc_task.brid_mv = brid;
sc_task.name_mv = name;
fromCount++;
sc_task.insert();
})(current, previous);
Unaware of what am doing wrong. Can you please suggest.
Shruti
Hi Shruti,
Can you try this.
var fromCount = 0;
var i;
var j;
var row;
for (i = 0; i < rowCount; i++) {
var peripheralType = row.u_please_select_type_of_computer_peripherals_mv;
var compPeripheral = row.u_please_select_computer_peripherals_mv.toString();
var abNumber = row.ab_number_mv;
var location = row.location_mv.toString();
var costCentre = row.cost_centre_mv.toString();
var brid = row.brid_mv;
var name = row.name_mv.toString();
fromCount++;
sc_task.insert();
Hi Asif,
I tried the above, problem is when i parse and try to get the data, value in the log is displayed as undefined.
Should the array values be split and moved to a variable?
Shruti
Have you had a look at the article I mentioned? Proven working mechanism.
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
LinkedIn
Community article list
Hi Mark,
I tried it for a catalog, and used current.variables.my_mrvs_name. I am getting the values entered in mrvs in an array, the tasks aren't created even after using parse. Just struck with it trying different methods to do it.
Also, I used flow designer which isn't affected when the changes are made to BR or runscript. Please suggest if anything else can be used to get this working.
var fromCount = 0;
var i;
var j;
var row;
gs.log('Parser: ' + parser);
gs.log('Parse Length: ' + parsed.length);
gs.log('peripheralType: ' + peripheralType);
gs.log('xxxcompPeripheral: ' + compPeripheral);
gs.log('xxxabNumber: ' + abNumber);
gs.log('xxxlocation: ' + location);
gs.log('xxxcostCentre: ' + costCentre);
gs.log('xxxbrid: ' + brid);
gs.log('xxxname: ' + name);
gs.log('SD: ' + short_description);
fromCount++;
sc_task.insert();
Right now i haven't mapped any WF or Flow Designer to catalog to check if the Tasks are created with BR alone.
Shruti
