Create each task for every entry on Multi Row Variable Set (MRVS)
Shruti Navalgu1
I am trying to create each task for every entry on the multi-row variable set. I am using flow designer to achieve but it doesn't work, please let me know if there is any other way to get through this
asifnoor
Hello Shruti,
You can write after Br on sc_req_item and can create catalog tasks. you can try like this
After insert on sc_req_item
condition: item is <your_cat_item>
Script
var mrvs = current.variables.your_mrvs_name;
var rowCount = mrvs.getRowCount();
for (var i = 0; i < rowCount; i++) {
  //if you wnat to read data from mrvs and assign to task then
  var row = mrvs.getRow(i);
  var sc_task = new GlideRecord("sc_task");
  sc_task.initialize();
  sc_task.short_description = row.your_variable;
  sc_task.insert();
Mark the comment as a correct answer and also helpful if it helps to solve the problem.
18 REPLIES 18
Hi Mark,
Yes it is a BR and the yes the BR is triggered as i could see the logs used in the script, please find the condition -
Shruti
Did you see my other comment? With updated script, tested and works.
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
LinkedIn
Community article list
Works instantly here. Only difference is I used field request_item:
	gs.info('>>> DEBUG');
	var rowsInt = current.variables.for_bulk_request.getRowCount();
	for(var i = 0; i < rowsInt; i++) {
		var grIncident = new GlideRecord('sc_task');
		grIncident.initialize();
		grIncident.setValue('request_item', current.getUniqueValue());
		grIncident.setValue('short_description', current.variables.for_bulk_request.getRow(i).u_name);
		grIncident.insert();
})(current, previous);
Kind regards,
Mark
LinkedIn
Hi Mark,
Thanks a ton ton ton (i was struggling last three days using all the ways to get this worked :)), i used the code in workflow, and it works perfectly fine now.
I removed the old script and updated with the one you provided me.
It is of great help :).
Shruti
