Create Excel Spreadsheet from script
09-01-2017 08:51 AM
I am attempting to run a background script to query a table, and put the results into a excel spreadsheet. I need to know if this is feasible from scripting and if so, what the best solutions would be.
Thanks in Advance,
Robert
09-14-2017 01:13 PM
Mike Meyers wrote:
How to create an excel like this? The only way I know would be to create a new table and list/view according to the required format, create those records via scheduled job and then use the ootb reporting/scheduled excel export. If possible, I would like to skip the "new table, new records" part. Is it?
You should be able to create a new list/view with a filter containing the required records against an existing table.
Consider creating it as a report with aggregate values (sum/count) in the rows and a grouping function - that should give you the data.
How it's exported as Excel, I'm not sure. (I'm not an Excel whizz - I tend to avoid it)
10-10-2017 01:39 PM
I have a trick, but need help to help us "I'm new on ServiceNow"
I think the function must exist somewhere in ServiceNow because we can use it a right click on a list:
So I looked in the "UI ACTIONS" but I did not find the script/function, somebody know where can found the script/function
04-18-2019 06:32 AM
Can I achieve this same by any SCRIPT?
Mean I can write the script to export data in Excel or CSV file?
11-03-2017 03:57 AM
Hi Robert,
Did you find any solution for this. We also have a similar requirement to create a spreadsheet from script.
Maddy
11-03-2017 04:12 AM
I suggest to create a report and configure a schedule email report to send it out by email in the format you desire.
Except you would reporting on system tables that is not allowed.
Hope it helps!
Valentina
