Create Problem is missing from incident context menu
Rishabh_N
I have a brand-new PDI, and I am practicing problem management.
I am trying to create a problem from an incident, but i don't see the "Create Problem" option in the incidnet form context menu.
when i right click the incident form header, i see options
such as:
Create Incident Task
Create Outage
Create Request
etc
but, Create Problem is missing .
Dr Atul G- LNG
Hi @Rishabh_N
ServiceNow has changed the licensing model, and the New Change is part of the Advanced offering. This might be the reason it is not appearing OOTB in your PDI. ServiceNow’s current guidance shows that Change Management capabilities have different licensing entitlements, while PDIs do not necessarily provide access to every licensed feature. (ServiceNow)
Please follow these steps to check and enable the available Change Management functionality in your PDI.
Latest Recommendation
If the above troubleshooting steps do not resolve the issue, install the following application:
SOW ITSM Advanced Applications
This application includes:
Change Management
Problem Management
Major Incident Management (MIM)
On-Call Scheduling
Walk-up Experience
Application ID: sn_sow_itsm_adv_ct
Recommended version: 9.1.1 or lower
Installing this application may enable the required Change Management and Problem Management capabilities in the PDI.
