‎06-17-2013 09:18 AM
We have a few currency fields in use in our system. The problem we are running into is that despite setting the code field as the display value for currency types the fields still show the symbol in the second drop down box. That is a problem because we use 3 currencies that use the $ symbol and end users have no way to determine what symbol to use.
Has anyone found a way to change that to use the currency code instead of symbol, or should I just edit the currency records and replace the symbol with the code again?
SS attached.
‎06-19-2013 04:04 PM
Hi John,
I've seen this done in other systems by adding a letter to the front of the $ sign to indicate the base country and remove the confusion.. i.e. Australian Dollars = A$, Singapore Dollars = S$ and you can leave USD as $ (or change to US$) to make it clear..
Matt
‎05-14-2014 04:08 AM
Thanks Adam - and yes that's what I did. Phew.
‎05-14-2014 04:19 AM
I think I left the page open for a while and in the meantime it got resolved!
‎05-03-2024 01:04 AM
Is the issue resolved iam facing same issue . I need dropdown for currency value instead i can see only logged in user currency only
‎05-21-2024 05:51 AM
I made this property to true and verified it is still not reflecting with its country code and its symbol
‎03-10-2021 03:07 PM
Review following knowledge article
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0755935
